POV-Ray : Newsgroups : povray.newusers : Any more characters in declared names possible ? Server Time
11 Oct 2025 10:58:37 EDT (-0400)
  Any more characters in declared names possible ? (Message 1 to 6 of 6)
Subject: Any more characters in declared names possible ?
Date: 16 Apr 2011 12:25:00
Message: <web.4da9c23e311bb397128f47250@news.povray.org>
working on the blender exporter, I came across some troubles when using
characters such as hyphens or dots in declared names. Is this restriction
usefull or could it be removed in later versions of POV-Ray ?
Subject: Re: Any more characters in declared names possible ?
Date: 16 Apr 2011 15:00:39
Message: <4da9e757$1@news.povray.org>
On 04/16/2011 01:22 PM, Mr wrote:
> Hi,
Not for certain, but the "dot" restriction may be in place for the case
of a vector identifier ... there are a whole slew of operators that may
apply ... just one example:
#declare Point = <5,10,0>;
object { Whatever translate Point.y }
Date: 16 Apr 2011 15:39:05
Message: <4da9f059@news.povray.org>
> Hi,
The hyphen will be interpreted as a minus sign.
If you have something like:
#declare A-B = 5;
#declare A = 1;
#declare B = 2;
Then you'll have a problem with this:
translate <A, B, A-B> been interpreted as translate<1,2,-1>
You have no way to diferensiate between A-B (the variable) and A-B (A
minus B)
The same way, you can't use any of those in a name:
Date: 20 Apr 2011 09:25:00
Message: <web.4daede8cc669e4df9a3b5fd00@news.povray.org>
Thanks, this will allow a more complete fix when I get the time.
Date: 9 May 2011 05:18:59
Message: <4dc7b183$1@news.povray.org>
Am 20.04.2011 15:24, schrieb Mr:
As a matter of fact, current versions of POV-Ray support only latin
upper- and lowercase letters (a-z, A-Z), underscore (_), and digits
(0-9). The latter cannot be used as first character of an identifier. As
for ASCII characters, it is unlikely that any other characters will ever
be added to the list of allowed identifier characters (unless some
special syntax would be added to support truly arbitrary identifier
names); As for non-ASCII Unicode characters, I currently wouldn't place
any bets either way.
Date: 9 May 2011 12:31:17
Message: <4dc816d5@news.povray.org>
  Technically UTF-8-encoded (non-ASCII) characters in identifier names
shouldn't be a problem because the encoding has been specifically
designed so that they won't (iow. no byte in a multi-byte character
will be a control character, a space, etc. if interpreted in ASCII).
It's just a question of the parser allowing for them.
