POV-Ray : Newsgroups : povray.newusers : Animate Text Around a Sphere Server Time
28 Jul 2024 02:24:49 EDT (-0400)
  Animate Text Around a Sphere (Message 1 to 10 of 21)
Subject: Animate Text Around a Sphere
Date: 6 Apr 2011 14:45:00
Message: <web.4d9cb36f58a0fabc6811d79b0@news.povray.org>
Hi Folks,
I am looking for help in animating a stream of text around a sphere, example
"News of the World" revolving around a globe. I remember it being done somewhere
but searches of the web have been unsuccessful.
Thanks in advance.
Digitaldad
Subject: Re: Animate Text Around a Sphere
Date: 6 Apr 2011 15:44:20
Message: <4d9cc294$1@news.povray.org>
On 06/04/2011 7:40 PM, digitaldad wrote:
> Hi Folks,
One way to do it would be to put each individual letter in a union
centred at the centre of the sphere. Then put all the text unions in
another union centred at the centre of the sphere. You would rotate the
individual text unions until you got the spacing you want then rotate
the final union for your animation.
Regards
Date: 6 Apr 2011 16:20:01
Message: <web.4d9cca2eabacefca81c811d20@news.povray.org>
> > Hi Folks,
> Regards
>      Stephen
If you want it as printed text, you could use the text object in an object
pattern, then apply a spherical warp to wrap the sphere.  You would have to play
with the relative scaling and geometry of the object pattern to get it
positioned and sized right, but that isn't too difficult of maths.
-tgq
Date: 7 Apr 2011 16:58:16
Message: <4d9e2568$1@news.povray.org>
>> Hi Folks,
>> example
>> somewhere
Bad practice, you should NOT use an union to contain a single object.
Why put each leter in an union? Each leter is an object and can be
manipulated as such.
Place all leters in a circle in an union. Have it centered at the
origin. Use rotate to have the leters move around.
You now only need to place your globe at the origin, possibly wraped in
an union with the text. You can now locate the whole thing as one unit.
union{
	union{#local Text_pos = 1
	 #while(Text_pos < Text_lenght)
	  text{ttf"arial.ttf" substr(Your_Text",Text_Pos,1),Thickness,0
translate -Radius*z rotate 320*y/Text_lenght}
	#local Text_pos=Text_pos+1;
	 rotate 360*clock*y
	 rotate -15*z //to tilt the rotating leters
	object{Globe}
	translate Your_Location
Adjust Radius and scale your letters as needed to get a nice spacing.
This gives you solid letters that you can make float around your globe.
Those leters are flat.
If you want the leters to have a rounded outer surface, then you can
intersect the letters from a sphere just large enough to contain them.
intersection{[the union of the letters goes here] sphere{0 Radius}}
You can diference another sphere to cut the back side of the letters.
difference{[the union of the letters goes here] sphere{0 Radius-Thickness}}
If you want your leters to travel ON the surface of your globe without
having any dicernable thickness, then you should use the proposition of
Trevor.
Date: 7 Apr 2011 21:33:32
Message: <4d9e65ec@news.povray.org>
On 4/6/2011 1:16 PM, Trevor G Quayle wrote:
>>> Hi Folks,
>> Regards
>>       Stephen
^This. The object pattern can be used to convert most objects into
pigments. The resulting pigment will always produce sharp results at any
resolution, unlike using, say, a bitmap image.
Sam
Date: 8 Apr 2011 04:23:06
Message: <4d9ec5ea$1@news.povray.org>
It is a technique for when you are using a modeller that does not have a
local axis.
Putting each letter in a union is a way of doing this.
Regards
Date: 8 Apr 2011 14:54:22
Message: <4d9f59de$1@news.povray.org>
> local axis.
I'm not sure I understand this. If you refer to the need
to apply individual transformations to each letter, then you
can use an "object" instead of a "union".
Date: 8 Apr 2011 16:15:13
Message: <4d9f6cd1@news.povray.org>
>> a local axis.
When you use a modeller like Moray or Bishop3D you cannot have anything
other than the Text object being on a plane. So to have the letters at a
constant distance from the centre or rotation without using any
mathematics, I create a letter at the origin and move it in the Z axis
to the correct position. Then I create a union at the origin and add the
letter. Next I copy the union and change the letter, repeat until I have
a word or phrase. I would then adjust the kerning manually by rotating
each union. To simplify orbiting the letters I create a final union at
the origin and add the other unions then translate and rotate the final
union.
It sounds a roundabout way of doing it but in reality it is very simple
and quick. If I were using Moray there would be no need to create unions
Regards
Date: 8 Apr 2011 19:20:50
Message: <4d9f9852$1@news.povray.org>
>>> a local axis.
> union.
Then, don't use a modeler for your text but use the text primitive to
create your individual letters. Unless a letter appears 100's times,
you'll use much less memory, you'll save parsing and loading time, and
the difference in render time won't be that important. Also, no faceting
nor mesh artefacts.
Anyway, the letters from those modelers are mesh objects, one mesh
object per letter, even for a word, with duplicated letters in the word
as several meshes. Missusing union causes many "Sould have more than one
objects in CSG". It also makes your code ugly.
Whenever you have one object union, you should use object.
Date: 8 Apr 2011 21:15:00
Message: <web.4d9fb1f4abacefcac2f1a7d40@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
....> Anyway, the letters from those modelers are mesh objects...
In this case no, the modelers (Moray, Bishop3d) export the POV-Ray object{text}
....>It also makes your code ugly...
Yes, it can be hard to read the exported code.
Stephen S
Moray and Bishop3d user :-)
