![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hy all!
I must do a believable emissive turbine for a spaceship. What methods should I
use for that?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 04/04/2011 9:52 AM, gregtom6 wrote:
> Hy all!
> use for that?
What is an emissive turbine and how would a roundy round thing fit in a
spaceship?
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hy all!
> use for that?
Just what is an "emissive turbine"?
You ether force some fluid into a turbine to get a circular motion or
use a circular motion to pump some fluid through the turbine, usualy at
great speed or persure.
NO "beleivable" spaceship EVER use a turbine for anything else than push
propergols into it rocket engines. Those turbines are usualy NOT visible
except in a closeup of the area behind the rockets. And, those looks
just like your regular turbine. Just take a look at a turbo charger for
a good example.
And no, SF movies spaceships are absolutely not beleivable except some
from Babylon 5. The Furyes fighters are the most beleivable space
fighters ever in any movie. Ther maneuvering is physicaly correct.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Alain <aze### [at] qwerty org> wrote:
> > Hy all!
> > use for that?
> a good example.
> Alain
I have already done with this emissive turbine. I have modified an another code,
what represents a candle flame.
Now I have a spaceship with blue flame.
I have a big problem. If I put this code to my pov file:
include "stars.inc"
sphere{ <0,0,0>, 1
texture{ pigment{color rgb<0,1,0>}//Starfield1 scale 0.2
} // end of texture
scale 1000000
Then I can't see the flame. How can I solve this problem? That's very important.
This is the code of the blue flame:
object{
merge{ // egg
intersection{
sphere{<0,0,0>,1} box{<-1,-1,-1>,< 1,1 ,1>} scale <1,2.5,1>}
intersection{
sphere{<0,0,0>,1} box{<-1,-1 ,-1>,< 1,0+0.01,1>} }
hollow
pigment { color rgbf<1, 1, 1, 1> } // fully transparent !!!
finish { ambient 0 diffuse 0 }
interior {
media {
//emission color rgb < 1.0, 0.75, 0.1>*1.75
emission color rgb < 0.0, 0.1, 1.0>*2.75
intervals 9
samples 1, 20
confidence 0.9999
variance 1/100
density{ spherical
ramp_wave
turbulence 0.15
color_map {
[0.0 color rgb <0.0, 0.0, 0.0>]
[0.6 color rgb <0.8, 0.3, 0.0>]
[0.9 color rgb <1.0, 0.8, 0.3>]
[1.0 color rgb <1.0, 1.0, 0.1>]
scale <1,2.5,1>
} // end density
}//end of media
media {
//emission color rgb < 1.0, 0.75, 0.1>*2.75
emission color rgb < 0.0, 0.1, 1.0>*5.75
intervals 3
samples 32
method 3
aa_threshold 0.1 aa_level 5
density {crackle turbulence 0.8
scale 0.75 translate<0,24,0>
color_map {
[0 rgb 0]
[0.00 rgb 0]
[0.07 rgb 1]
[0.10 rgb 1]
[0.12 rgb 0]
[1.00 rgb 0]
} // end density
density {spherical
color_map {
[0 rgb 0]
[0.7 rgb 1]
[1 rgb 1]
} // end density
scale <2,5,2>*0.5
translate<0,0.01,0>
}// end media
}//end of interior
//scale <1,1.5,1>*0.5
//rotate<90,90,0>
scale <1, 1.5,1 >*0.5
translate <-2.5, -5, -0.3>
rotate<90,90,0>
hollow // !!!!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> include "stars.inc"
> sphere{ <0,0,0>, 1
> } // end of texture
> scale 1000000
Add the "hollow" keyword to the big sphere, as media
will not work inside a non-hollow object.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Christian Froeschlin <chr### [at] chrfr de> wrote:
> > include "stars.inc"
> > sphere{ <0,0,0>, 1
> > } // end of texture
> > scale 1000000
Thanks a lot:) You saved me so much time.:) Thanks again.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Media tip:
> interior {
> media {
> //emission color rgb< 1.0, 0.75, 0.1>*1.75
> emission color rgb< 0.0, 0.1, 1.0>*2.75
> intervals 9
This MUST remain at the default value of 1.
> samples 1, 20
The second value is always ignored.
Use:
intervals 1
samples 100 // because of the crackle pattern
It should render faster.
> confidence 0.9999
Not needed.
> variance 1/100
Also not needed.
> density{ spherical
> media {
2 medias in the same container should use the same parameters.
> //emission color rgb< 1.0, 0.75, 0.1>*2.75
> emission color rgb< 0.0, 0.1, 1.0>*5.75
> intervals 3
Keep at intervals 1
> samples 32
samples 100
> method 3
Method 3 is the default, you don't need to force it.
The actual default values for media are:
method 3
intervals 1
samples 10
confidance (NOT used)
variance (NOT used)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It looks like what you call a "turbine" should be called a "rocket
thruster" or "rocket engine"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Media tip:
> > interior {
> > media {
> > intervals 9
> > samples 1, 20
> Use:
> intervals 1
> > confidence 0.9999
> Not needed.
> > variance 1/100
> Also not needed.
> > density{ spherical
> > media {
> > intervals 3
> Keep at intervals 1
> > samples 32
> samples 100
> > method 3
> method 3
> intervals 1
> samples 10
> variance (NOT used)
> Alain
Sorry, but I experience slowly rendering...There's a giant difference in
rendering speed, using these tips I get a very slow rendering.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Alain<aze### [at] qwerty org> wrote:
>> Media tip:
>>> interior {
>>> media {
>>> intervals 9
>>> samples 1, 20
>> Use:
>> intervals 1
>>> confidence 0.9999
>> Not needed.
>>> variance 1/100
>> Also not needed.
>>> density{ spherical
>>> media {
>>> intervals 3
>> Keep at intervals 1
>>> samples 32
>> samples 100
>>> method 3
>> method 3
>> intervals 1
>> samples 10
>> variance (NOT used)
>> Alain
It's probably because, in your original scene, with your original
parameters, you had only 9 samples for each medias: 1 for each
intervals, with the settings from the first media overiding those of the
second.
Now, each medias get sampled 100 times and you get very acurate results.
There are chance that you can use less samples. Try something like
samples 20 to samples 30
much beter performances. The more intervals there are, the slower the
rendering speed.
intervals 10 samples 5 (50 total samples) is MUCH slower than
intervals 1 samples 100 that have twice the number of samples.
Your media with the crackle pattern going from intervals 3 samples 32 to
intervals 1 samples 100 get faster and have 4 more samples.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
