POV-Ray : Newsgroups : povray.newusers : How to get preserve color through an intersection call? Server Time
5 Oct 2024 18:24:32 EDT (-0400)
  How to get preserve color through an intersection call? (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: How to get preserve color through an intersection call?
Date: 3 Oct 2010 15:15:00
Message: <web.4ca8d5dc627fd6a8881e51860@news.povray.org>
Hi Alain,
> Whenever you use a difference or intersections, the various surfaces
> take the texture of the object that define THAT surface. The end of the
> cutouts thake their colouration from the sphere and their sides from the
> cylinders.
Ahh, I did not realize this. That fact helps a lot.
> You need to make your pierced shell, then place coloured and transparent
> pieces into the holes.
> You can make some sets of cutouts and give each the desided colouration.
> One red set, one green set and one blue set in your case.
I see that I must go this route now. Thanks.
> A side note: Why not let POV-Ray compute the end points of your
> cylinders? Just use a cylinder like this one:
> cylinder{0, 10*x, 0.5}
Does "10*x" simply mean <10,0,0>? I'm guessing so. I don't see how that would
make it all that much cleaner though because then I would have to determine the
rotation to place it where I wanted for each one and each cylinder would then
have more data specifying it than in my original case. Unless I misunderstand...
> Then, you rotate it to where you want it. This gives you a cleaner code.
> Also, when you have very small values like 5.66549845232e-15, you can
> replace them with 0 (zero), the difference is absolutely negligeable. In
> fact, usualy, any value smaller than 1e-6 can be changed to zero.
Yes, that's definitely true. But I generate the cylindrical syntax from a python
script that I wrote, and that is how it's outputted with no formatting. I could
make it cleaner and have it report 0 instead of these really small numbers, but
I wasn't intending to use the bunch_of_cylinders block as something that I
planned to read and change by hand anyway.
Thanks for your help! I'll make the changes after lunch and see how it looks!
Date: 3 Oct 2010 15:19:02
Message: <4ca8d726$1@news.povray.org>
ha-ha ... I thought making the shell yellow instead of black (without
any sky_sphere) would have led to that discovery ;-)
Date: 3 Oct 2010 15:50:00
Message: <web.4ca8dd7c627fd6a8881e51860@news.povray.org>
Hmm, good point. Here's what I think you are suggesting:
http://yfrog.com/epcodebp
And you can see the problem from this image. A somewhat unrelated question: I
have a light source in the center of the sphere. Is there a way to make that
light source brighter?
Thanks,
Brad
Date: 3 Oct 2010 16:12:50
Message: <4ca8e3c2@news.povray.org>
A quick answer is yes. Just multiply the colour like:
colour rgb <1,1,1> * 10
Or
colour rgb <10,10,10>
Best Regards,
Date: 3 Oct 2010 16:19:12
Message: <4ca8e540$1@news.povray.org>
nothing wrong with rgb <2,2,0> for a light color ... fade_distance, and
fade_power are options. Be sure you check out:
http://aries/wiki/index.php/Documentation:Reference_Section_4.3#Light_Sources
depending on the "look" you're going for there might be ways to do this
other than using a light source ... there's more than one way to trace a
ray! ;-)
Date: 3 Oct 2010 16:22:15
Message: <4ca8e5f7@news.povray.org>
sheesh ... long day ... this addy would probably do better!
http://wiki.povray.org/content/Documentation:Reference_Section_4.3#Light_Sources
Date: 3 Oct 2010 16:50:01
Message: <web.4ca8ec73627fd6a8881e51860@news.povray.org>
Thanks for the continued help everyone. I'm slowly making progress.
Here is what I've got so far. The ball, with a Silver_Metal texture, surrounded
by 5 walls. I added a bit of ambient light to it so that you could see the
silver ball a bit better, although I think it looks like real crap.
http://yfrog.com/jvcodeup
Any ideas on how I could light the scene besides this ambient look to make it
look nicer? When I added a light_source right behind the camera it didn't look
too good because of a sort of black shadow that was always visible behind the
ball, as seen in the following:
http://yfrog.com/j5codeghp
Once I get the scene looking a little nicer I play on rotating the ball and
making a movie out of it, but I'm not fully happy with how it looks right now.
Ideas?
Is there a way for me to visualize the light rays that are hitting the wall, as
if there were dust in the air? Would I just fill the observable area with a
white box with almost perfect transparency? Or is there a more professional way
to do this (surely....)?
Date: 3 Oct 2010 17:00:00
Message: <web.4ca8ee50627fd6a8881e51860@news.povray.org>
Moving the disco ball to the top makes it look a little better just because the
walls aren't all the same anymore.
http://yfrog.com/f7codekp
Date: 3 Oct 2010 17:35:01
Message: <web.4ca8f689627fd6a8881e51860@news.povray.org>
Just learned about scattering media, so I'll try to figure it out. Thanks again!
Date: 3 Oct 2010 17:47:45
Message: <4ca8fa01$1@news.povray.org>
You will need to use photons and fill the scene with scattering media.
Read 3.6.2.1  Media Types
And for an example look at optics.pov in \POV-Ray\v3.7\scenes\advanced
To make this work the container for the media needs the "hollow" flag set.
3.4.9.5  Hollow.
Fun, fun, fun ;-)
Best Regards,
