Subject: Re: How to get preserve color through an intersection call?
Date: 4 Oct 2010 22:49:25
Message: <4caa9235$1@news.povray.org>
> Thanks for these additional comments Alain. However, before I read them I
> already ran a case at 20 samples and 20 iterations, with the output below (and
> also rotating the cube a bit so the light isn't shining in the camera's eyes).
> http://yfrog.com/2mcode20int20samplesp
> It took a little over 4 hours to render on my desktop (ran it overnight). I can
> really see how those doing much, much more complicated scenes run into
> ridiculous rendering times.
> Alain<aze### [at] qwertyorg> wrote:
>>> I figured out my issues, which were numerous. Here is my current result:
>>> http://yfrog.com/fvcode5int5samplesp
>>> Took 22 minutes to render on my computer. I'm steping up the interval and
>>> sampling rate to make a better image though. This program is mind-blowingly fun
>>> Thanks for all the help. No more questions in this thread :)
>> Don't increase the intervals value as it will kill your render times.
>> Only increase samples.
>> samples 100 will render faster than intervals 10 samples 5 for twice the
>> total samples.
>> While you can use samples 10, 100, only the "10" will be used ans the
>> "100" will be totaly ignored.
>> The defaults value from the documentation are for smpling method 1. The
>> default sampling method is method 3. It's defaults are:
>> intervals 1 // NEVER change that!
>> samples 10 // MUST be 3 or larger.
>> Alain
I notted an anomaly in your scene:
The spots are set into 6 sets of 9, for a total of 56. The problem is
that you have 84 cylinders, and looking further, you have LOTS of
duplicates like: <0,0,10> <-0,0,10> <0,-0,10> and <-0,-0,10> with many
apearing in 2 or even 3 colours sets. (manualy changing very small
values to zeros helped a lot to spot those)
Those duplicates increase your render time and cause coincident surfaces
artefacts each time that you have more than 1 colour at the same place.
Date: 5 Oct 2010 16:12:38
Message: <4cab86b6@news.povray.org>
>> below (and
>> camera's eyes).
>> overnight). I can
>>>> result:
>>>> interval and
>>>> mind-blowingly fun
>>> total samples.
>>> Alain
> Alain
After removing 18 duplicates (6 for each colours, only for the
orthogonals ones and not checking between colours sets), I got an
impressive boost in my render time. Down to 66 elements down from the
original 84. Sould be further reduced to 54.
Still have 3 for <0,0,10> and <0,0,-10> that have all 3 colours.
Resolving those removes 4 more elements-> down to 62.
It should be noted that intersection and difference are inherently poor
at bounding: Any ray that encounter those need to be tested against all
components. This also apply to the shadow rays. So the less components
you have, the faster the shadow rays can be evaluated.
I'm thinking of another aproach:
Have only a plain sphere and place a collection of tight spot_light in
it's center. Add double_illuminate to make the spots visible on the
surface. Add no_shadow so that the beams can continue outside of the sphere.
You use the points that you have presently as the point_at for the spots.
Now, any duplicate will be obvious due to the increased lighting.
Date: 6 Oct 2010 13:21:22
Message: <4cacb012$1@news.povray.org>
> sphere.
> Alain
Using that, I got some dramatic speed improvement, about 20 times faster.
The only thing been that if you want to see the bright spots the sphere
can't be black. It can be dark and using fading lights that are very
bright at short distance the spots will show as bright coloured areas.
> > sphere.
> > Alain
> Alain
Thanks for all those additional suggestions and the catching of duplicates
Alain, I really appreciate it! I'm out of town at the moment but I look forward
to playing around with some of your suggestions once I get back.
