POV-Ray : Newsgroups : povray.newusers : Why is this happening when I change the background to white? Server Time
7 Apr 2026 15:29:12 EDT (-0400)
  Why is this happening when I change the background to white? (Message 1 to 10 of 10)
Subject: Why is this happening when I change the background to white?
Date: 30 Sep 2010 19:20:00
Message: <web.4ca51a5ad353eca9c40be0560@news.povray.org>
Hi, I'm a physicist that uses POVRAY to visualize crystal structures and
electronic properties of materials.
I have generated the following image with POVRAY
http://yfrog.com/0sdefaulteop
Now if I set the background from black (0,0,0) to white (255, 255, 255) I get
the following image:
http://yfrog.com/n4whitebackgroundp
Notice that a lot of the blue stuff in the corners and edges of the box is now
missing.
The header (and so probably the relevant info) of my .pov file is below
#declare camera_location = <-0.10, -0.50, 0.90>;
#declare camera_look_at = <0.00, 0.00, -0.00>;
#declare camera_scale = 22.17;
#declare light_location = camera_location - camera_look_at;
#declare light_scale = 1e6;
#declare color_light = rgb <2.00, 2.00, 2.00>;
#declare color_background = rgb <0.00, 0.00, 0.00>;
#declare radius_frame = 0.01;
#declare color_frame = rgb <0.75, 0.75, 0.75>;
#declare color_box = rgbf <1.00, 1.00, 1.00, 0.75>;
#declare length_axis = 3.82;
#declare radius_axis = 0.08;
#declare color_axis_x = rgb <1.00, 0.00, 0.00>;
#declare color_axis_y = rgb <0.00, 1.00, 0.00>;
#declare color_axis_z = rgb <0.00, 0.00, 1.00>;
#declare length_arrow = 0.2 * length_axis;
#declare radius_arrow = 2.0 * radius_axis;
#declare color_arrow_x = color_axis_x;
#declare color_arrow_y = color_axis_y;
#declare color_arrow_z = color_axis_z;
#declare radius_atom_si = 0.42;
#declare radius_bond_si = 0.15;
#declare color_atom_si = rgb <0.50, 0.60, 0.60>;
#declare color_bond_si = rgb <0.50, 0.60, 0.60>;
#declare radius_atom_p = 0.39;
#declare radius_bond_p = 0.15;
#declare color_atom_p = rgb <1.00, 0.50, 0.00>;
#declare color_bond_p = rgb <1.00, 0.50, 0.00>;
#declare color_isosurface_positive = rgbf <0.40, 0.40, 0.80, 0.75>;
#declare color_isosurface_negative = rgbf <0.80, 0.40, 0.40, 0.75>;
The blue surface is defined by the color_isosurface flags at the bottom, and
setting those from a rgbf to a purely rgb setting fixes the missing surface that
I have in that picture. However, I want my iamage to be semi-transparent. Is
there anything I can do?
Thanks so much for your help!
Subject: Re: Why is this happening when I change the background to white?
Date: 1 Oct 2010 05:40:01
Message: <web.4ca5ab6bb4921ef62a36ae330@news.povray.org>
I think you lose your transparency because your background becomes equal to your
box color (both white). Maybe the setting of your color_light to < 2.00, 2.00,
2.00 > has something to do with the rest of the picture, but I'm not
knowledgeable enough to answer for that.
Joost
Date: 1 Oct 2010 05:45:01
Message: <web.4ca5ac67b4921ef62a36ae330@news.povray.org>
Oh, and white isn't < 255, 255, 255>, but < 1, 1, 1>.
Date: 1 Oct 2010 12:30:35
Message: <4ca60cab$1@news.povray.org>
> missing.
<snip>
The cube in your black background piece also has a few artifacts showing
up along the edges as well. I am guessing the problem is not in how you
are coloring the boxes, but how you are bounding the objects involved.
This is just a guess, but the artifacts do look like the coincident
surface problem. If the transparent box is exactly the same size or in
the same exact place as the surface you use to create the edges of the
blue interior surface, the rays can't calculate which they hit first,
and artifacts appear. More of your code would be useful to see if that
is the issue, but you can try just scaling the visible box by some small
amount to see if that corrects some or all of the problem.
Date: 1 Oct 2010 12:48:24
Message: <4ca610d8$1@news.povray.org>
> missing.
> #declare camera_location =<-0.10, -0.50, 0.90>;
> #declare camera_look_at =<0.00, 0.00, -0.00>;
> #declare color_light = rgb<2.00, 2.00, 2.00>;
> #declare color_background = rgb<0.00, 0.00, 0.00>;
> #declare color_frame = rgb<0.75, 0.75, 0.75>;
> #declare color_box = rgbf<1.00, 1.00, 1.00, 0.75>;
> #declare color_axis_x = rgb<1.00, 0.00, 0.00>;
> #declare color_axis_y = rgb<0.00, 1.00, 0.00>;
> #declare color_axis_z = rgb<0.00, 0.00, 1.00>;
> #declare color_atom_si = rgb<0.50, 0.60, 0.60>;
> #declare color_bond_si = rgb<0.50, 0.60, 0.60>;
> #declare color_atom_p = rgb<1.00, 0.50, 0.00>;
> #declare color_bond_p = rgb<1.00, 0.50, 0.00>;
> #declare color_isosurface_positive = rgbf<0.40, 0.40, 0.80, 0.75>;
> #declare color_isosurface_negative = rgbf<0.80, 0.40, 0.40, 0.75>;
I made some tests using a few concentrical spheres using your color.
No problem if I use a background of rgb 1 or rgb 2.
Increasing the rgb value beyong that and I see surfaces disapearing.
As you used rgb 255 for the background, there is no way that you could
see all surfaces. It cuts through the first 4 surfaces.
Date: 1 Oct 2010 12:50:29
Message: <4ca61155$1@news.povray.org>
>> box is now
>> missing.
> <snip>
>> bottom, and
>> surface that
The real problem is the background:
backgroung{rgb 255}
Changing it to:
backgroung{ rgb 1}
corrects the problem nicely.
Date: 1 Oct 2010 16:50:00
Message: <web.4ca6493eb4921ef6c40be0560@news.povray.org>
Thanks so much for the help everyone! The problem indeed is fixed if I change
the (255, 255, 255) to (1, 1, 1). I'm very new with all this stuff and a quick
google search for 'white rgb' somehow led me to the 255 values.
While I'm here, what resources would you guys recommend for someone who wants to
learn more about POVRAY? I'd mostly like to have the ability to generate
beautiful graphics for scientific papers and presentations. I saw a couple
tutorials online that I'm going to try to work through today, but wanted to know
if there was anything better to look at. Really amazed at the kind of images
POVRAY can produce!
Thanks again,
Brad
> >> box is now
> >> missing.
> > <snip>
> >> bottom, and
> >> surface that
> backgroung{rgb 255}
> Changing it to:
> backgroung{ rgb 1}
> Alain
Date: 1 Oct 2010 18:57:48
Message: <4ca6676c$1@news.povray.org>
Have you visited http://www.povray.org/resources/ ... it's certainly a
good place to start :-)
Date: 1 Oct 2010 20:48:09
Message: <4ca68149$1@news.povray.org>
You should also rear through the provided documentation and play with
the various sample scenes. You make a change and see the effect it causes.
Date: 2 Oct 2010 02:54:52
Message: <4ca6d73c$1@news.povray.org>
>>> who wants to
And of course there are these newsgroups.
Best Regards,
