![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am getting v. confused.
When I render this file (ss.pov):
location <.2,0,2.4>
look_at <0,0,0>
angle 36
sphere{<0,0,0>,.5
texture {pigment {color rgb<118,23,255>}}
With this command:
povray ss.pov
I get a white circle on a black background
When I do it with this command:
povray ss.pov Output_Alpha=True
I get a magenta circle on an alpha channel background.
I assumed that, in each case, since there was no light source, the whole scene
should be black. Can someone tell me where the light comes from?
.... and why rendering with an alpha channel produces different results (outside
the alpha area)?
Thanks
Gobnat
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Color in POV-Ray is from 0 to 1, you may want 255/255 for example.
Color outside of this range is clipped at some point to this range(not shure
when).
There is a default background color of black.
Does this help?
Stephen S
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> camera {
> location<.2,0,2.4>
> look_at<0,0,0>
> angle 36
> sphere{<0,0,0>,.5
> With this command:
> povray ss.pov
> the alpha area)?
> Thanks
> Gobnat
There is no light_source, but there is the default ambient finish of 0.1
that make that overly bright pigment visible.
color rgb<118,23,255> gives rgb<11.8, 2.3, 25.5> after the ambient is
applied, and gets clipped to rgb<1,1,1> whitch is white.
POV-Ray use the 0..1 range for the colours.
0 means nothing for that channel, 1 means full intensity for the channel.
Change it to:
texture {pigment {color rgb<118,23,255>/255 } finish{ ambient 0 }}
This turns the ambient off and bring the pigment back in the correct range.
Take note that values larger than 1 are acceptable, but can have
unexpected results. There are cases where large values are needed, such
as fading lights.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > the alpha area)?
> Change it to:
Dear Alain and Stephen
Thank you so much for this explanation. You have done a great service for my
sanity - I was going batty trying to work it out. (Still not quite sure why the
alpha channel version rendered a non-white circle, but happy enough am still
sane.)
Regards
G
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
