POV-Ray : Newsgroups : povray.newusers : Image mapping onto shere Server Time
19 Nov 2025 00:56:52 EST (-0500)
  Image mapping onto shere (Message 1 to 4 of 4)
Subject: Image mapping onto shere
Date: 20 Jan 2010 16:10:01
Message: <web.4b576f88ca4826f2135358dc0@news.povray.org>
I've searched for hours but just can't find a clear definition of how an image
is wrapped around a sphere. The best I can get - and it's far from perfect - is
with the following code, arrived at by trial and error - the image being 2:1
width to height. If I knew what the rules were I might do better! Maybe someone
can clarify this for me.
Thanks, Geo
sphere { <0,0,0>, 1 texture
         pigment { image_map {jpeg "lines3.jpg" }
         scale <2,2,1>
         translate  <0, 1, 0>
Subject: Re: Image mapping onto shere
Date: 20 Jan 2010 16:58:34
Message: <4b577c8a$1@news.povray.org>
Spheres are supported by UV mapping,
so...
sphere {0,1 pigment {
   uv_mapping
   image_map {jpeg "lines3.jpg"}
should work fine. In the more general case
(since not all objects are supported by UV mapping),
   image_map {
      jpeg "lines3.jpg"
      once // don't repeat the image
      map_type 2 // cylindrical
   translate <0,-0.5,0> // center the image on origin
   scale <1,2,1> // double the height to match diameter of sphere
All this assumes that your starting image is a cylindrical
map. When you are looking at a cylindrical map there is
distortion near the top and bottom of the image, this means
that to do vertical lines, they are no longer straight, but hourglass
shaped in the source image, otherwise the lines will pinch in
narrower at the poles. So they're a bit hard to manually create
in a paint program, but such images are available online for the
earth and most of the planets.
Date: 21 Jan 2010 10:55:00
Message: <web.4b5878a558ffb9ec846dd2f80@news.povray.org>
> so...
>    uv_mapping
>    image_map {
>       jpeg "lines3.jpg"
Many thanks, works fine! I already had a suitable POVray cylinder image for
Earth but hadn't twigged the uv-mapping aspect. From a few tests I've done it
seems the aspect ratio of the image is not important - it gets stretched to
cover the sphere. Very handy.
Thanks again
Geo
Date: 10 Feb 2010 07:31:09
Message: <4b72a70d$1@news.povray.org>
>>    image_map {
>>       jpeg "lines3.jpg"
>> [...] such images are available online for the
For completeness' sake, be advised that the typical projection used for
planetary "image maps" is "equidistant cylindrical" (aka "plate carree")
projection, that is the coordinates in the image correspond to the
latitudinal and longitudinal angles - which does NOT match POV-Ray's
map_type 2, but rather map_type 1 ("spherical").
The terms used in POV-Ray are a bit misleading, as in cartographers'
terms both are "normal cylindrical" projections, with type 2 being very
rarely used in cartography, if at all.
