POV-Ray : Newsgroups : povray.newusers : Scattering media tips Server Time
19 Nov 2025 00:55:12 EST (-0500)
  Scattering media tips (Message 1 to 3 of 3)
Subject: Scattering media tips
Date: 1 Jan 2010 13:05:00
Message: <web.4b3e38f7b2c903fc34d207310@news.povray.org>
I'm playing with scattering media & spotlights. I was trying to find a set of
conditions where I could "see" the same thing either in close-up or faraway.
So far, if I get a set of conditions that look cool in a close-up, the scene is
"black" when viewed faraway.  This makes sense in that I guess an amount of
scattering that is able to interact significantly with a spotlight will absorb
everything when seen faraway.
Any tips on how to make a cool spotlight-in-fog setting that gives similar views
independent of camera location?
thanks.
Subject: Re: Scattering media tips
Date: 1 Jan 2010 14:56:46
Message: <4b3e537e$1@news.povray.org>
I take this to mean the media extends to "faraway", so you are
actually looking through more "stuff" from the distance. You could
try limiting the media to a smaller container or use a density which
is higher in the cone of the spotlight. It's cheating of course, but
then what you ask for might be an unrealistic effect ;)
You could also try using less dense media with a brighter light
source but stronger fading (smaller fade_distance).
Date: 12 Jan 2010 20:15:00
Message: <web.4b4d1e823f50255de40bffa00@news.povray.org>
Thanks. Now that I think about it, I think the problem was that I was
simultaneously using two different camera_view pigments in Megapov, and this
just threw everything into craziness with media.  The media was even blocking
some of the color from the camera_view's themselves.
