POV-Ray : Newsgroups : povray.newusers : light_group issue? Server Time
14 Aug 2025 04:01:47 EDT (-0400)
  light_group issue? (Message 1 to 5 of 5)
Subject: light_group issue?
Date: 30 Oct 2009 21:25:00
Message: <web.4aeb90cad28430d75f7f8dc0@news.povray.org>
I'm make some tests with light_group and I think that something is wrong.
The scene has five objects and three lights (area, spot and point):
http://www.4shared.com/file/145000763/dff075b7/light-scene.html
.... and I had put all together in the same light_group:
light_group {
  spot9  // yellow light
  wo_4_cube
  wo_3_cone
  wo_0_floor
  wo_2_sphere_front
  wo_1_sphere_back
  global_lights false
this is the result:
http://www.4shared.com/file/145000640/750d2cb8/Grouped_-_Yellow_Spot.html
perhaps ok. So, I repeat the test to point and area light:
http://www.4shared.com/file/145000652/82187cd5/Grouped_-_Red_Point.html
http://www.4shared.com/file/145000633/a345ebc5/Grouped_-_White_Area.html
it's all ok.
then I had removed the wo_3_cone from first test above and the cone received the
all lights influence (like spected):
http://www.4shared.com/file/145000690/c0a352f5/Grouped_-_Yellow_Spot_-_Cone_out.html
but when I had removed (only) the wo_1_sphere_back, wo_1_sphere_back and
wo_3_cone, both of them had received all lights influence (not spected):
http://www.4shared.com/file/145000686/30dbc681/Grouped_-_Yellow_Spot_-_Back_Sphere_out.html
the code was
light_group {
  wo_4_cube
  wo_3_cone
  wo_0_floor
  wo_2_sphere_front
//  wo_1_sphere_back
  global_lights false
there is others situations that I think is incorrect. Plese take a look at
http://www.4shared.com/dir/15476894/ca82d09a/Figuras.html
there is the pov source file (teste luzes.pov) and the others result tests.
TIA
Subject: Re: light_group issue?
Date: 30 Oct 2009 22:19:56
Message: <4aeb9ecc$1@news.povray.org>
The normals on your meshes are reversed, it's inside out.
Date: 30 Oct 2009 22:54:55
Message: <4aeba6ff$1@news.povray.org>
There's no "reversed normals" on a mesh unless it uses inside_texture.
Date: 30 Oct 2009 23:23:16
Message: <4aebada4@news.povray.org>
> the code was
> light_group {
>   wo_4_cube
>   wo_3_cone
>   wo_0_floor
>   wo_2_sphere_front
> //  wo_1_sphere_back
>   global_lights false
You probably have some misconceptions about how POV-Ray handles
#declare'd objects, and especially how light groups work.
When you specify
     #declare MyObject = mesh2 { ... }
you actually declare a "template" object, which will not be visible in
the scene - /never ever/. It can only serve to derive similar objects
from it, which in turn can be visible in the scene.
When you later specify
     object { MyObject ... }
you create such a derived object, which /will/ be visible; you /can/
choose to leave it unchanged, but it will still not be identical to the
template object known as "MyObject".
Therefore, obviously the following construct:
     light_group { ...
       object { MyObject }
will /not/ assign the template object "MyObject" to a light group - that
wouldn't make any sense, because the template object itself isn't
visible anyway. Nor would it make sense to have this syntax assign each
and every object you derived from "MyObject" to the light group, as you
may want multiple such derived objects with some inside and some outside
the light group.
What the syntax actually does is to create /yet another/ derived object
from "MyObject", and assigns /that/ one to the light group.
So if you want to have two objects in your scene, one inside and one
outside of a light group, you should use:
     #declare MyObject1 = mesh2 { ... }
     #declare MyObject2 = mesh2 { ... }
     object { MyObject1 ... } // this one is outside the light group
     light_group { ...
       object { MyObject2 ... } // this one is inside the light group
Note that "MyObject2" appears /only/ inside the light group statement.
Otherwise you'd get two copies of it - one inside and one outside - and
POV-Ray would show just one of them more or less at random, like it
always does wherever the surfaces of two or more objects coincide.
Date: 16 Nov 2009 10:45:01
Message: <web.4b01732bea525fae75f7f8dc0@news.povray.org>
After your explanations I think that the problem was my misconception about
objects declaration (in the true: "template" declaration).
I'll try some changes on my scene and verify the results. If I get other
question I come back here.
Thanks
