POV-Ray : Newsgroups : povray.newusers : Simple question Server Time
16 Dec 2025 03:35:14 EST (-0500)
  Simple question (Message 1 to 10 of 19)
Subject: Simple question
Date: 4 Oct 2009 06:35:00
Message: <web.4ac879683b0d195ed001f37b0@news.povray.org>
Hello. Is there any mood in POV-Ray to change the default output file type?
Thanks.
Subject: Re: Simple question
Date: 4 Oct 2009 06:56:09
Message: <tpvgc5t9hae1lr5i5i66fu9dn9qjaepj7r@4ax.com>
>Thanks.
Yes there is, read the documents/help section 3.1.2.4.1  Output File Type.
Regards
Date: 4 Oct 2009 08:17:00
Message: <4ac8923c@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:tpvgc5t9hae1lr5i5i66fu9dn9qjaepj7r@4ax.com...
>>type?
>>Thanks.
... and, in particular the INI file syntax, which is Output_File_Type=J (or
one of the listed types), which you can put into the 'povray.ini' file to
make it the default behaviour on your system.
The 'J' option gives jpeg output (which I think is missing from the
documentation). On Windows you can edit 'povray.ini' from the Tools menu and
you shouldn't need to restart POV-Ray afterwards.
Chris B.
Date: 4 Oct 2009 08:40:01
Message: <web.4ac896e53f8a411c67b294d0@news.povray.org>
> >>type?
> >>Thanks.
> Regards,
> Chris B.
Hmm, did not know this was still there.
On the other hand, ick, very poor quality.
-tgq
Date: 4 Oct 2009 08:50:39
Message: <4ac89a1f@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.4ac896e53f8a411c67b294d0@news.povray.org...
>> >>type?
>> >>Thanks.
>> > Type.
>> (or
>> and
>> Regards,
>> Chris B.
Ah yes! When I mention the JPEG option I really should also warn that it
seems to do something strange with colours (at least on my Windows Vista
system). It's not by any means a recommendation to use that particular
format and it would have been better if I'd have used another format to
illustrate my point. POV-Ray generated jpeg files display ok in Netscape,
but the thumbnails and the windows image viewer both show bizarre colours
which dissapear if I load and save the output from a graphics editor.
Chris B.
Date: 5 Oct 2009 00:15:01
Message: <web.4ac9720b3f8a411cac4259f0@news.povray.org>
I'd never heard of "+fj"!   It's always seemed missing even if jpeg is a better
distribution format than a "mastering" format.  I can imagine there being some
rare uses.  That said, I have to agree with Trevor's comment. :)
Charles
Date: 5 Oct 2009 04:47:48
Message: <4ac9b2b4$1@news.povray.org>
"Charles C" <nomail@nomail> wrote in message
news:web.4ac9720b3f8a411cac4259f0@news.povray.org...
> better
> some
Well, yes and no. JPEG is a lossy format (it's designed that way), but I
find it by far and away the most convenient when working on graphics
destined for web pages. Any implication that it's not a worthy format to be
supported by POV-Ray makes me a tad nervous. I think it should find its way
into the documentation, with a warning that it's not a loss-free format and
that the results will unavoidably contain JPEG artifacts. People could then
simply use another format for any process that requires some sort of top
quality master.
Chris B.
Date: 5 Oct 2009 07:19:38
Message: <4ac9d64a@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4ac8923c@news.povray.org...
> documentation).
A convenient link so you can add that if you like:
http://wiki.povray.org/content/Doc:Reference_Section_1.1#File_Output_Options
I also started a talk page so you can make the changes:
http://wiki.povray.org/content/Documentation_Talk:Reference_Section_1.1
once you do that I'll merge changes into the original!
Jim
Date: 5 Oct 2009 14:17:23
Message: <4aca3833$1@news.povray.org>
"Jim Holsenback" <jho### [at] povrayorg> wrote in message
news:4ac9d64a@news.povray.org...
> Jim
saw your changes ... and they've been merged back into the original doc.
thank you very much!
Jim
Date: 5 Oct 2009 19:05:01
Message: <web.4aca7a1c3f8a411291cf5a40@news.povray.org>
> > better
> > some
> quality master.
> Regards,
> Chris B.
Sorry, no anxiety intended. ;)  I agree JPEG output is a good option to have
available.  One feature which could make it even better would be a quality
option. For example "+fjxx" where "xx" is a numeric quality level similar to
what you can enter when saving a JPEG in GIMP.
(Disclaimer: I don't know just how quick or easy this would be to implement, and
I imagine it would be of relatively low priority compared to other things.)
I think depending on the content of an image, JPEG can be more distracting than
at other times.  For instance, I tried +fj on a test render with very simple
textures, some fine detail and a blue sky sphere.  It looked bad.   I suspect
the more a rendering looks like a photo (i.e. no shortage of detail so you're
not staring at one little spot which you can't see clearly), the less
distracting JPEG artifacts might be for a given compression level.
Charles
