POV-Ray : Newsgroups : povray.newusers : different lighting in scene Server Time
12 Oct 2025 00:46:21 EDT (-0400)
  different lighting in scene (Message 1 to 5 of 5)
Subject: different lighting in scene
Date: 1 Sep 2009 09:25:00
Message: <web.4a9d1ff8cdbdcd722a36ae330@news.povray.org>
I'm running into a problem with the lighting of my scene. I want to light the
background of my scene differently from the foreground. Can I combine two
scenes both with their own lighting, or appoint a light to a single (group of)
object(s)?
Using a parallel light in the back of my scene also lights the front. Using
fading is causing me new problems (I would like to be able to just cut a light
off at a certain point). Does anybody know a simple solution?
Thanks, Joost
Subject: Re: different lighting in scene
Date: 1 Sep 2009 11:35:58
Message: <4a9d3f5e@news.povray.org>
> Hi,
> object(s)?
> Thanks, Joost
You can use a light_group.
Any light_source in a light group only shine on the objects that are
part of that light_group.
By default, those objects are also not lighted by any light_source that
are NOT part of the light_group. If you want to ALSO receive light from
other sources, you need to add "global_lights on" to the light_group.
An object that is not part of a light_group CAN cast shadows on the
objects of a light_group.
Date: 1 Sep 2009 11:37:29
Message: <4a9d3fb9@news.povray.org>
> Hi,
> object(s)?
> Thanks, Joost
If you use the Windows version, look at section "3.4.8  Light Groups"
from the included documentations.
Date: 1 Sep 2009 12:05:01
Message: <web.4a9d43d678d9f3602a36ae330@news.povray.org>
Grrrr. I've read through the whole 3.4.7 Light section numerous times and
struggled with fading lights and the answer was right under my nose. Totally
missed the next chapter.
Thanks a lot! (meant sincerely, not cynical)
Date: 2 Sep 2009 13:35:19
Message: <4a9eacd7$1@news.povray.org>
No problem. Everybody does just that, at least some of the time....
