POV-Ray : Newsgroups : povray.newusers : rendering edges Server Time
16 Dec 2025 11:08:22 EST (-0500)
  rendering edges (Message 1 to 10 of 13)
Subject: rendering edges
Date: 10 Aug 2009 07:55:00
Message: <web.4a8009b2789d6f5be3f0b2880@news.povray.org>
What's the easiest way to render faceless edges and give them any material or
texture.
Best would be if the solution allows me to insert its code into the object block
because of the way the exporter works.
Subject: Re: rendering edges
Date: 10 Aug 2009 11:06:05
Message: <4a80375d$1@news.povray.org>
> texture.
Usually thin cylinders are used for this purpose, combined with spheres
at the vertices to prevent artifacts.
Date: 11 Aug 2009 08:25:01
Message: <web.4a8161934068d214e3f0b2880@news.povray.org>
> > texture.
Hmm... but how can I find the right vertices pairs in such an output mesh:
 vertex_vectors {1108,<-0.0582308,0.879374,-0.00541553>,[ETC...] }
 normal_vectors {1108,<-0.489174,-0.0570892,0.870316>,[ETC...]}
 face_indices {2208,<0,1,2>,<2,3,0>,<4,5,6>,<6,7,4>,<8,9,10>,<11,12,13>,[ETC...]
 normal_indices { 2208,<0,1,2>,<2,3,0>,<4,5,6>,<6,7,4>,<8,9,10>,[ETC...]}
(I don't get why there are face indices whereas the mesh is only edges but
anyway...) Should I assume that vertices are exported consecutively on a same
edgeloop? Since I have a constant n number of verts over these edgeloops should
I chop these coordinates by such amounts of n vectors to use in spheresweeps?
Date: 11 Aug 2009 11:14:40
Message: <4a818ae0$1@news.povray.org>
"Mr" <nomail@nomail> wrote in message
news:web.4a8161934068d214e3f0b2880@news.povray.org...
> clipka <ano### [at] anonymousorg> wrote:
>> > material or
>> > texture.
>> > object block
> face_indices
> same
> should
> spheresweeps?
I get the impression that you're asking about rendering a sort of wire-frame
view of the mesh2 object where the edges are shown, but where the faces are
not. This is not all that straight-forward because, when adding a mesh or
mesh2 object to a scene POV-Ray draws triangular faces to construct the
surface of the object. The face data contains values which index the vertex
data to tell it where to draw each triangular face, so the first face in
your example <0,1,2> uses the first three vectors defined as vertex_vectors
etc. Edges don't really come into it in any direct way when you simply
render such an object.
If you do want to create a sort of wire-frame view, then the easiest way is
probably to #declare the vertices and the faces as two arrays of 3-element
vectors:
#declare MyVectors = array [1108]
{<-0.0582308,0.879374,-0.00541553>,[ETC...] };
#declare MyFaces = array [2208]
{<0,1,2>,<2,3,0>,<4,5,6>,<6,7,4>,<8,9,10>,<11,12,13>,[ETC...]};
Then you can quite easily loop through the faces and draw 3 cylinders for
each edge of each triangular face, giving those cylinders more or less any
texture you want.
If this is what you want to do then I'd be happy to post an example of a
simple #while loop that would do this sort of thing for you.
Chris B.
Date: 11 Aug 2009 16:58:35
Message: <4a81db7b$1@news.povray.org>
> anyway...)
POV-Ray *only* has "faced" meshes; there's nothing it can do (natively)
with edges anyway. Therefore of course the program you used to design
the mesh with assumed you wanted a "faced" mesh when it exported to
POV-Ray format.
No, what you'll actually need to do is traverse the list of faces,
connecting the vertices with edge cylinders as you go along, and make
sure to deal with duplicates (each edge will typically be listed twice)
by either:
(a) build an edge list from the face definitions, checking for each
additional edge whether you already encountered it (can quickly become
quite parsing-heavy)
(b) rely on the mesh comprising a closed surface (no "open faces"), and
be "sane" regarding inside/outside orientation (which is defined by the
order in which the vertices are listed), so that each edge appears
exactly twice, with opposite ordering of vertices; you can then draw the
edge only if the first vertex index is lower than the second (or vice
versa, at your discretion)
(c) ignore the problem of duplicate vertices, and simlpy add the
respective cylinder twice; if they have the same texture, there
shouldn't be a problem regarding coincident surface artifacts.
Date: 11 Aug 2009 17:15:01
Message: <web.4a81df0e4068d214e3f0b2880@news.povray.org>
> vectors:
> texture you want.
> Regards,
> Chris B.
Actually, there should'nt be any triangles since they are just extruded vertices
forming a long uninterrupted continuous series of edges like a spline without
interpolation. (hair)
 so they should'nt be arrays of 3 edges... only pairs one after the other. I
feel it should be easier to convert those to actual geometry on blender side.
but eve if I don't make it, it's not worth the effort. It's not as if hair
didn't get exported, just some of its curlyness set up into its child
particles.
Date: 11 Aug 2009 20:09:24
Message: <4a820834$1@news.povray.org>
news:web.4a81df0e4068d214e3f0b2880@news.povray.org...
> vertices
> without
> I
> side.
> particles.
Ah! Ok. My first assumption was all wrong then.
There definitely are triangular faces in the file snippet you posted,
although it's not possible to see whether the triangles are degenerate,
because you only show the first vertex and I'd need to see the first 3
vertices to be able to say whether the first triangle is degenerate (two or
more vertices in the same place).
I now assume you're creating a surface and extruding the vertices in
Blender, then exporting as an 'obj' file that you convert to POV-Ray using
the excellent PoseRay utility written by FlyerX.
If this new assumption is correct, then the sample you posted must have
contained some sort of surface defined in Blender when you exported it,
otherwise you wouldn't get any faces in the mesh2 object.
When you export to Wavefront-obj format from Blender, the generated 'obj'
file contains a set of 3 and/or 4 sided faces to represent surfaces and a
series of 2-sided faces for the straight-line segments.  If you then convert
this to POV-Ray using the PoseRay utility that FlyerX wrote, it converts any
3 and 4 sided faces into triangular faces within a mesh2 object and ignores
the 2-sided faces. This means that any 'hairs' created as extruded vertices
forming a "long uninterrupted continuous series of edges" will be lost and
you will end up with only the original surface from which they were
extruded.
The good news is that the 'obj' file format can give you the 'edge' data you
would need to reconstruct the 'hairs' in POV-Ray. To display these in
POV-Ray you'll need a script to go through the 'obj' file looking for
2-sided face definitions and adding a POV-Ray cylinder to represent each
'edge'. Here's a simple 'obj' file I exported from Blender, having created a
4-sided face (a plane) and extruded the 4 vertices. I then extruded the
first of those 4 vertices a second time (f 9 5) giving a total of 5 edges.
# Blender3D v248 OBJ File: linetest2.obj.blend
# www.blender3d.org
mtllib linetest2.mtl
v 0.970005 -0.000000 -1.014998
v 0.970005 0.000000 0.985002
v -1.029996 0.000000 0.985002
v -1.029995 -0.000000 -1.014998
v 2.334797 -0.000000 -2.424784
v 0.445084 0.000000 1.599909
v -1.554916 0.000000 1.599909
v -1.554915 -0.000000 -0.400091
v 3.969549 -0.000000 -3.174670
usemtl (null)
s off
f 1 4 3 2
f 1 5
f 2 6
f 3 7
f 4 8
f 9 5
The 'obj' file shows the resulting 9 vertices. The 4-sided face uses
vertices 1, 4, 3 and 2 and the five extruded 'hairs' are each represented as
a 2-sided face. Writing a simple script to create a set of straight-line
cylinders to represent these Blender 'edges' should be fairly
straight-forward. If you wanted to get more sophisticated it would be
possible to match up adjacent 'edges' to create a nice smooth spline, but
this is likely to be significantly more complex.
If you used some other way to generate the code snippet you posted, then it
is possible that it contains a sequence of degenerate triangles representing
just the 'edges' (the 'hairs'). This would need a different solution to be
able to see make it visible in a POV-Ray scene.
Chris B.
Date: 14 Aug 2009 09:55:00
Message: <web.4a856c494068d214e3f0b2880@news.povray.org>
> > vertices
> > without
> > I
> > side.
> > particles.
> extruded.
> # www.blender3d.org
> usemtl (null)
> s off
> f 1 4 3 2
> f 1 5
> f 2 6
> f 3 7
> f 4 8
> f 9 5
> Regards,
> Chris B.
Thanks For this very well explained tip on faceless edges in obj format.
Although I'm using Blend2Pov instead of the Obj export, the problem seems to be
much more simple: after checking up again, what I had copied was another mesh
of the scene. The faceless mesh didn't get  exported at all.
Date: 14 Aug 2009 10:58:07
Message: <4a857b7f$1@news.povray.org>
news:web.4a856c494068d214e3f0b2880@news.povray.org...
> to be
> mesh
Ah ok! So my second guess was wrong too then :-)
I didn't know about Blend2Pov. That looks like a very interesting project.
It looks as though it will generate more than just mesh2 objects, but I
didn't find anything describing what it does with Blender edges that don't
form part of a face. Is there a document somewhere to describe what it
generates?
Chris B.
Date: 14 Aug 2009 13:40:00
Message: <web.4a85a04f4068d214e3f0b2880@news.povray.org>
> > to be
> > mesh
> generates?
> Regards,
> Chris B.
No document, I don't know how the original patch by RCRuiz is commented:
http://code.google.com/p/blend2pov/
JMS won't release the current modified source, but I'll just ask him about those
faceless edges. If you speak french and are interested in this tool here is the
forum of JMS.
http://www.zoo-logique.org/3D.Blender/newsportal/thread.php?group=3D.Pov-Ray
