POV-Ray : Newsgroups : povray.newusers : Very slow rendering of an object with many holes Server Time
16 Aug 2025 00:05:14 EDT (-0400)
  Very slow rendering of an object with many holes (Message 1 to 8 of 8)
Subject: Very slow rendering of an object with many holes
Date: 21 May 2009 12:50:01
Message: <web.4a1585be2b4d1dd4bbb61a180@news.povray.org>
Hello, I have another question.
My scene has a plate with many (about 1000) holes, like following:
difference{
  cylinder{<0,0,0>,<0,1,0>,10}
  #local X=-9; #while(X<9)
    #local Y=-9; #while(Y<9)
      #if (X*X+Y*Y < 81)
        cylinder{<X,-0.1,Y>,<X,1.1,Y>,0.1}
    #local Y=Y+0.5; #end
  #local X=X+0.5; #end
Rendering of this is very slow, even if I added bounded_by.
On the other hand, if I removed CSG, it is much faster.
How can I improve the rendering speed?
Subject: Re: Very slow rendering of an object with many holes
Date: 21 May 2009 13:45:01
Message: <web.4a1592bddc3f4a9cc0721a1d0@news.povray.org>
> difference{
>       #if (X*X+Y*Y < 81)
>       #end
I think the following link provide an answer:
http://www.econym.demon.co.uk/holetut/index.htm
Steven
Date: 21 May 2009 14:31:14
Message: <4a159df2$1@news.povray.org>
You're in luck, there is an entire tutorial just on holes ;)
Date: 21 May 2009 14:32:58
Message: <4a159e5a$1@news.povray.org>
oops as stevenvh already posted, should have hit update before send ;)
Date: 21 May 2009 15:25:00
Message: <web.4a15aa63dc3f4a9ce1d5d3040@news.povray.org>
This is a general problem with CSG objects that have a lot of cut-outs. It has
to do with how POV uses (or, as in this case, doesn't use) bounding.
If your holes are placed at regular intervals, one solution would be to assemble
the plate from 1000 elements having a single hole each. This is actually a good
deal faster, because in this case POV-Ray will apply bounding to each of these
elements for good effect.
If the holes are cylindrical, you can also make creative use of the blob object,
by defining the holes collectively as one single blob with 1000 cylinder
elements, instead of 1000 individual cylinder objects; IIRC, this should give
you some speed advantage as well, because blobs (like meshes) have their own
bounding mechanism.
Date: 22 May 2009 18:50:00
Message: <web.4a172aa8dc3f4a9c20aaa4ac0@news.povray.org>
Thank you for your helps.
My object has regular arrangement of cylindrical holes, but
I cannot guess a function because:
- holes are arranged in hexagonal way
- no "half" holes at edge of the object
- (if possible) a small part of edge of holes should be cut in 45 degree
On the other hand, usage of blob worked almost well, but
it cannot satisfy the third requirement written above.
Date: 23 May 2009 10:01:51
Message: <4a1801cf@news.povray.org>
"Tomohiro" <nomail@nomail> wrote in message
news:web.4a172aa8dc3f4a9c20aaa4ac0@news.povray.org...
The following example took a little longer than I'd anticipated to write,
mainly because I'd not read your first posting carefully enough and didn't
initially realise you wanted a cylindrical object. Anyway, the approach I
took was basically the same and could be made to work with a variety of
shapes:  I've declared a 'blank' box without a hole and a 'holed' box of the
same size so that they can be slotted together in the same sort of way that
Mike's tutorial shows, but each of the boxes is just big enough to take one
hole.
The nested #while loops lay the boxes out in a grid, with a few conditional
statements to determine what to place where (based on the calculated centre
point for that box). The first condition is that, if it's well outside the
circle it doesn't bother placing an object there at all. The second says
that, if it overlaps the edge, trim it using a CSG intersection with a
cylinder. If the centre would make the hole touch the edge it uses the
'blank' object, otherwise it uses the 'holed' object.
I hope I've correctly interpreted what you meant when said you wanted the
holes laid out in an 'hexagonal way'. I've interpreted this as a 50% offset
in successive rows, giving a hexagonal/triangular pattern (ie with prominent
diagonal lines of holes), but it should be fairly easy to replace every
third hole on each line with a 'blank' giving a pure hexagonal pattern.
This example rendered 1618 holes in 2 seconds on my machine.
camera {location  <-1, 2,-4> look_at 0}
light_source {< 70, 200, -80> color rgb 0.8}
#declare XHoles = 50;
#declare XSep = 0.1;
#declare ZSep = 0.5*XSep*sqrt(3);
#declare ZHoles = int(XHoles*XSep/ZSep);
#declare Radius = (XHoles*ZSep)/2;
#declare BlankObject = box {<-XSep/2,-0.1,-ZSep/2><XSep/2,0,ZSep/2> }
#declare HoledObject = difference {
  object {BlankObject}
  cylinder {<0,-0.05,0><0,0.05,0>,0.02}
  cone {<0,-0.05,0>,0,<0,0.05,0>,XSep/2}
#declare HoleCount = 0;
union {
  #declare I =-(XHoles-1)/2;
  #while (I<(XHoles/2))
    #declare J = -(ZHoles-1)/2;
    #while (J<(ZHoles/2))
      #local ThisCentre = <XSep*(I+mod(J,2)/2),0,J*ZSep>;
      // If it's part of the object
      #if (vlength(ThisCentre)<(Radius+XSep/sqrt(2)))
        // If it's part of the edge
        #if (vlength(ThisCentre)>(Radius-XSep/sqrt(2)))
          intersection {
            #if (vlength(ThisCentre)<(Radius-0.05))
              object {HoledObject translate ThisCentre}
              #declare HoleCount = HoleCount + 1;
            #else
              object {BlankObject translate ThisCentre}
            cylinder {<0,-0.11,0><0,0.1,0>,Radius}
        // If it's clear of the edge
        #else
      #declare J = J + 1;
    #declare I = I + 1;
  pigment {rgb 1}
cylinder {<0,-0.5,0><0,-0.12,0>,Radius pigment {rgb <1,1,0>}}
#debug concat(str(HoleCount,3,0)," Holes.\n")
Chris B.
Date: 23 May 2009 14:10:00
Message: <web.4a183ae8dc3f4a9cefff66860@news.povray.org>
.... so looks like you need to resort to solution #1: Small building blocks with
just a few holes each. One type for the "bulk" of the object, and another few
for the edges.
