POV-Ray : Newsgroups : povray.newusers : Cutaway_textures Server Time
12 Oct 2025 06:28:02 EDT (-0400)
  Cutaway_textures (Message 1 to 6 of 6)
Subject: Cutaway_textures
Date: 11 Jul 2008 05:55:00
Message: <web.48772d6758ea35f669b634a70@news.povray.org>
I'm having trouble using the cutaway_textures feature when trying to cut
something with a complex csg. The following simplified code illustrates my
problem:
camera {location <3,4,-4> look_at 0 }
light_source {<10,20,-5>, rgb 3}
#declare MyObject = union {
  box {<-1,-1,-1>,<1,0,1> pigment {Red} }
  box {<-1,0,-1>,<1,1,1> pigment {Blue}}
#declare MyCuttingObject = difference {
  cylinder {<0,-2,0>,<0,2,0>,1}
  box {<0,-3,-1>,<1,3,0>}
difference {
  object {MyObject}
  object {MyCuttingObject}
  cutaway_textures
I've got two colored boxes on top of each other, which I want to cut with an
object that is a construction of two objects. Obviously I would like to see the
colors inside the cut, hence the cutaway_textures, but this doesn't seem to
work. Is there anyone who has the golden tip?
Thanks!
Boud
Subject: Re: Cutaway_textures
Date: 11 Jul 2008 06:32:55
Message: <487736d7@news.povray.org>
"BoudewijnDocter" <nomail@nomail> wrote in message
news:web.48772d6758ea35f669b634a70@news.povray.org...
> Hi,
> problem:
*** Add  pigment {Yellow} here  ***
> difference {
>  object {MyObject}
>  object {MyCuttingObject   *** or here ***}
>  cutaway_textures
> an
> see the
> to
> Thanks!
> Boud
Your cutting object doesn't currently have a texture defined for it, so it
comes out black. If you add a pigment it should work.
Chris B.
Date: 11 Jul 2008 08:50:01
Message: <web.48775656beb19c4a69b634a70@news.povray.org>
> > Hi,
> > problem:
> > difference {
> >  object {MyObject}
> >  cutaway_textures
> > an
> > see the
> > to
> > Thanks!
> > Boud
> Regards,
> Chris B.
Thanks for your quick reply, but it doesn't seem to solve the problem.
Now the inside becomes Yellow, so the cutaway_textures does not seem to do
anything. Is this a bug? What version should I use? I'm currently running
V3.6.1 for Windows
Date: 11 Jul 2008 09:55:00
Message: <web.487764b9beb19c4a69b634a70@news.povray.org>
> > > Hi,
> > > problem:
> > > difference {
> > >  object {MyObject}
> > >  cutaway_textures
> > > an
> > > see the
> > > to
> > > Thanks!
> > > Boud
> > Regards,
> > Chris B.
> V3.6.1 for Windows
Some additional comments on this subject:
The problem seems to be the difference statement in MyCuttingObject. If I change
this into a union, the scene renders without problems. Looking at the
documentation concerning cutaway_textures (sect. 3.5.10) it gives the following
syntax:
  difference | intersection {
    OBJECT_1_WITH_TEXTURES
    OBJECT_2_WITH_NO_TEXTURE
    cutaway_textures
This suggests that the second object should not have any texture. My suspicion
now is that the difference function in MyCuttingObject results in a csg with
(partially?) default textures (like what would happen if you leave the
cutaway_textures statement out). If this suspicion is right, then removing all
texture information should do the trick, but how?
Does anyone know a method of removing all texture information from a csg?
Thanks!
Boud
Date: 11 Jul 2008 10:51:55
Message: <4877738b$1@news.povray.org>
news:web.48775656beb19c4a69b634a70@news.povray.org...
>> > Hi,
>> > cut
>> > my
>> > problem:
>> > difference {
>> >  object {MyObject}
>> >  cutaway_textures
>> > with
>> > an
>> > see the
>> > seem
>> > to
>> > Thanks!
>> > Boud
>> it
>> Regards,
>> Chris B.
> V3.6.1 for Windows
Ah. Sorry yes I see what you mean.
If MyCuttingObject is defined as just a cylinder the finished object
inherits red and blue cutaway surfaces from the object that you cut into,
whereas if you use a CSG object as MyCuttingObject it inherits the surface
texture of the cutting object.
I did run across a similar issue recently and, unless I'm missing something,
I think it may well be a bug. I don't see anything in the help that outlaws
using a 'difference' CSG object as the cutting object with cutaway_textures.
Chris B.
Chris B.
Date: 11 Jul 2008 11:33:38
Message: <Mk5Yb2BUy3dIFwAh@econym.demon.co.uk>
Wasn't it BoudewijnDocter who wrote:
>Hi,
>problem:
>difference {
>  object {MyObject}
>  cutaway_textures
It looks like a bug. A rather ugly workround is to do this:
union {
  difference {
    object {MyObject}
    cutaway_textures
  intersection {
    object {MyObject}
    cutaway_textures
Mike Williams
Gentleman of Leisure
