POV-Ray : Newsgroups : povray.newusers : rounding Server Time
28 Mar 2026 10:22:44 EDT (-0400)
  rounding (Message 17 to 26 of 26)
Subject: Re: rounding
Date: 28 Jun 2008 15:07:33
Message: <48668C29.90908@hotmail.com>
Warp wrote:
> Slime <fak### [at] emailaddress> wrote:
>> floor( A + 0.5 )
>> (Although this will cause -3.5 to be rounded to -3, which I'm not sure is
>> correct.)
you could use ceil(A-0.5) in that case or even use a switch for >0 and <0
>   Why would rounding it to -4 be more correct? 3.5 is equally close to
> either value.
depends on convention. There as thus 4 ways to round halves:
up,down,towards zero and away from zero.
Date: 28 Jun 2008 15:09:51
Message: <48668c7f@news.povray.org>
  Actually there's a fifth convention which is also widely used: Round
to the closest even number. I believe the idea behind this one is that
tries to even out systematic bias in lengthy calculations.
Date: 28 Jun 2008 15:17:05
Message: <48668E65.6080306@hotmail.com>
Not to mention the university teacher that recommended alternate up and
down rounding for even less bias ;) . I have seen libraries of functions
for the four I mentioned but not for this round to even or the
alternating one or the random one you mentioned earlier.
Date: 29 Jun 2008 14:05:00
Message: <web.4867ce3d42ba7542bfec89d20@news.povray.org>
didnt read it. I've seen less complex functions work and not work neagtive-wise,
depending on the sytem. handle negs, int() instead of floor() in POV should
solve the neg issue
#macro round(f,n)
  #local c = floor(pow(10.0,n));
  #local d = 0.5 / c;
  #local d = d + abs(f);
  #local d = d * c;
  #local d=floor(d);
  #local d = d/c;
  #if (f < 0.0) #local d = d * -1; #end
  (dd)
functions rain overkill mode:
#macro incenter(A,B,C)
      #local a = C*vlength(A-B);
      #local b = A*vlength(B-C);
      #local c = B*vlength(C-A);
      #local d = vlength(A-B)+
                 vlength(B-C)+
                 vlength(C-A);
  #local result = (a+b+c)/d;
  result
#macro centroid(A,B,C)
  #local result = (A+B+C)/3;
  result
#macro circumcenter(A,B,C)
      #local a = vlength(A-B);
      #local b = vlength(B-C);
      #local c = vlength(C-A);
      #local sp = (a+b+c)*0.5;
   #local cosineR = ((b*b + c*c - a*a)/(2*b*c))*
      a*b*c/(4*sqrt(sp*(sp-a)*(sp-b)*(sp-c))); //circumradius(A,B,C);
   #local mp = (A+B)/2; //midpoint(A,B)
   #local result = mp+(vnormalize(vcross(A-mp,vcross(C-B,A-B)))*cosineR);
   result
   /* "walks" to cCenter in 3D.
      Algebra core step=cos(angle)*R.
      Input order irrelevant since both (A-mp)
      and norm vectors reverse in sync */
#macro outcenter(A,B,C)
   circumcenter(A,B,C)
#macro ccenter(A,B,C)
   circumcenter(A,B,C)
#macro orthocenter(A,B,C)
      a*b*c/(4*sqrt(sp*(sp-a)*(sp-b)*(sp-c))); //outeradius(a,b,c);
   #local cc = mp+(vnormalize(vcross(A-mp,vcross(C-B,A-B)))*cosineR);
   #local result = ((A-cc)+(B-cc)+(C-cc)) + cc;
   result
#macro inner_radius(A,B,C)
   #local result = 0.5*sqrt(((b+c-a)*(c+a-b)*(a+b-c)) / (a+b+c));
   result
#macro tetrahedron_volume(A,B,C,D)
  #local result = abs(vdot(D-A,vcross(D-B,D-C))) / 6;
  result
#macro pyramid_volume(A,B,C,D,E)
  // perimeter order for 1st 4 points
  #local result =
     tetrahedron_volume(A,B,C,E) + tetrahedron_volume(A,C,D,E);
  result
#macro triangle_area(A,B,C)
     //2D .z must be 0
   #local result = abs((B.x*A.y - A.x*B.y)+
                       (C.x*B.y - B.x*C.y)+
                       (A.x*C.y - C.x*A.y)) / 2;
   result
#declare inneradius = function(a,b,c) {
   //(3 lens)
#macro circumradius(A,B,C)
   #local result = a*b*c/(4*sqrt(((a+b+c)/2)*(((a+b+c)/2)-a)*
                   (((a+b+c)/2)-b)*(((a+b+c)/2)-c)));
   result
#declare outeradius = function(a,b,c) {
  //(3 lens)
  a*b*c/(4*sqrt(((a+b+c)/2)*(((a+b+c)/2)-a)*(((a+b+c)/2)-b)*(((a+b+c)/2)-c)))
  //(a*b*c) / (4*sss_area(a,b,c))
#declare sas_area = function(s,a,s2) {
   0.5 * s * sin(a) * s2
#declare sas_cos = function(s,a,s2) {
   sqrt((pow(s,2)+pow(s2,2))-2*s*s2*cos(a))
} // Side Angle Side - solve length of missing side
#declare sas_height = function(s,a,s2) {
    s*sin(a)*s2/sqrt((pow(s,2)+pow(s2,2))-2*s*s2*cos(a))
   //sas_area(s,a,s2) / (sas_cos(s,a,s2) * 0.5)
} // SAS height to missing side
#declare bh_area = function(b,h) {
   //(base,height)
   0.5 * b * h
#declare sss_height = function(a,b,c) {
  sqrt(((a+b+c)/2)*(((a+b+c)/2)-a)*(((a+b+c)/2)-b)*(((a+b+c)/2)-c))/(b*0.5)
  //sss_area(a,b,c) / (b * 0.5)
} // height to side2
#declare sss_area = function(a,b,c) {
   //semi perimeter
#declare vmyv = function {
//function that returns a vector
   transform {
     rotate <0, 0, 0>
     scale 1
#declare aas_sin = function(a,b,s) {
   sin(b) * (s / sin(a))
} // AAS solve opposing side of angle2 (b)
#declare asa_sin = function(a,s,b) {
   sin(b) * (s / sin(pi-(a+b)))
} // ASA solve opposing side of angle2 (b)
#declare sss_cos = function(a,b,c) {
   acos((pow(a,2)+pow(c,2)-pow(b,2))/(2*a*c))
} // SSS solve angle opposite side2 (b)
  // if (pow(a,2)+pow(c,2)-pow(b,2))/(2*a*c) < 0 obtuse
#declare ssa_acute = function(s,s2,a) {
   asin(s2*sin(a)/s)
} // SSA solve angle opposite side2
alias sss_area2 {
  ; (3 lens)
  return $calc(0.5 * ($1 + $2 + $3) * $inneradius($1,$2,$3))
alias sss_area3 {
  ; (3 lens)
  return $calc(($1 * $2 * $3) / (4 * $circumradius($1,$2,$3)))
Date: 29 Jun 2008 17:58:50
Message: <486805CE.2020701@hotmail.com>
alphaQuad wrote:
> didnt read it.
read what?
> solve the neg issue
There is no "neg issue". People have different expectation on what e.g.
floor() should do for negative numbers. It is more or less arbitrary,
but it has to be defined. I agree that round() could be added as a
function in POV4. Preferably not as a macro. Macro's tend to be written
again and again. That is a waste of time and possibly dangerous as well
if someone implements it subtly different from somebody else.
Date: 29 Jun 2008 18:03:02
Message: <48680696@news.povray.org>
  AFAIK the floor() function is universally defined to round downwards,
as the name implies. In other words, the return value is always smaller
or equal to the parameter.
> I agree that round() could be added as a function in POV4.
  Why? floor(value+.5) does the same thing.
Date: 29 Jun 2008 18:31:28
Message: <48680D75.9030509@hotmail.com>
yes (except perhaps on very old equipment that had a sign bit and not
2s-complement), but that does not stop people from expecting that
floor(-x+.5)==-floor(x+.5) everywhere.
I was talking about expectations not definitions. (ok, 'would' in stead
of 'should' would (should?) have been better)
no it doesn't, that was the whole point. In some cases people want a
function that round halves away from zero. round(-3.5)=-4
Date: 29 Jun 2008 18:54:59
Message: <486812c3@news.povray.org>
  Why would anyone want to round halves away from zero? And if someone
*really* wants that, he can make his own function which does that. The
rest can use either floor(value+.5) or ceil(value-.5), whichever they
prefer.
Date: 30 Jun 2008 15:58:37
Message: <48693aed$1@news.povray.org>
andrel nous illumina en ce 2008-06-29 18:32 -->
That expectation come from the fact that many peoples considere 0 to be smaler
than -1, whitch is false. Many peoples have the tendency of ignoring the sign
when quickly comparing values, only concidering the absolute value instead of
the real one.
A short cut is the longest distance between two points.
Date: 3 Jul 2008 18:57:51
Message: <486D59A5.4050308@hotmail.com>
> smaler than -1, whitch is false. Many peoples have the tendency of
> ignoring the sign when quickly comparing values, only concidering the
> absolute value instead of the real one.
I don't think so. Anyway, this example did not express what I meant :(
BTW one reason for thinking that there may be a reason why people expect
round(-3.5) to be -4 is that Matlab thinks so too.
