POV-Ray : Newsgroups : povray.newusers : Render segmented image - how? Server Time
18 Dec 2025 05:44:44 EST (-0500)
  Render segmented image - how? (Message 1 to 8 of 8)
Subject: Render segmented image - how?
Date: 22 Feb 2008 09:30:00
Message: <web.47bedb24e47a3773d2e4c6e60@news.povray.org>
I have a 3D voxel image of 256 by 256 by 256 voxels of a heart, which is already
segmented. Let's assume that the left ventricle is marked by a 1 in the image,
the right ventricle by a 2, the outside by a 0. I would like to render the
geometry in povray, with the surface of the segments smoothed out, left
ventricle in blue, right in red. I need reflection on the surface, meaning I
want to define a solid object.
I could produce a geometry file that contains lots of small boxes given with
their full dimensions, and unite them for the respective objects, or a massive
number of blobs - but that seems uneffective, and I failed to create a smooth
(!) volume from these blocks anyway.
Any suggestions? I couldn't find a simple object that does what I need. Maybe it
can be done with a density file? I tried to, but couldn't get reflections on the
surface to work.
Frank
Subject: Re: Render segmented image - how?
Date: 22 Feb 2008 11:02:22
Message: <8fstr31i1ja3f2q5ca9fnkpl5ivlk2kiho@4ax.com>
On Fri, 22 Feb 2008 09:25:20 EST, "Frank" <wue### [at] uni-muensterde> wrote:
>Any suggestions?
How about a blob?
Date: 22 Feb 2008 12:14:47
Message: <47bf0307$1@news.povray.org>
Frank nous apporta ses lumieres en ce 2008/02/22 09:25:
> surface to work.
> Frank
You can use that as a density pattern usine a color_map set with the correct
values. Apply that pattern to an emissive media.
This method will give you a transparent volumetric rendering: you will see the
interior. As there is no real surface, you won't reflect anything. It's like
trying to get a reflection on some gaz.
You can scan the data and create a blob. Place a small sphere component for all
non-zero voxels. Each blob components will receive a pigment depending on the
value of the voxel they represent. If the inside of the cavities are zero as the
exterior, they will be open. Experiment with the threshold value, and the
components radius and strength until you get an acceptable result.
The resulting object can be made reflective. You won't see the internal parts.
You can combine both: Make the blob, make it transparent with some reflection in
the finish, add "hollow" and fill it with some media modulated with the density
file.
Presbyterian: This shit was bound to happen.
Date: 22 Feb 2008 13:10:00
Message: <web.47bf0fa85defef6f402ca5f10@news.povray.org>
Thank you! That's exactly what I needed. I hadn't understood the concept of
Blobs.
Frank
Date: 22 Feb 2008 14:51:39
Message: <47bf27cb$2@news.povray.org>
Frank wrote:
> I hadn't understood the concept of Blobs.
Don't worry about it, the suggestion was completely wrong for your problem.
	Thorsten, POV-Team
Date: 22 Feb 2008 17:15:01
Message: <web.47bf487b5defef6fd2e4c6e60@news.povray.org>
Interesting. Is there anything you'd suggest, then?
Thank you, Frank
Date: 22 Feb 2008 23:06:29
Message: <w79ncjHNr5vHFwqh@econym.demon.co.uk>
>is already
>Maybe it
>reflections on the
>surface to work.
Have you tried using your density file to drive an isosurface? That will
produce an actual surface that can have a reflective finish. I don't
know if it will do smoothness.
See: http://www.econym.demon.co.uk/isotut/patterns.htm#density
Mike Williams
Gentleman of Leisure
Date: 23 Feb 2008 02:15:01
Message: <web.47bfc7765defef6f26eb43d10@news.povray.org>
Yes! That's the easiest way without having to create the external blobs. I
overlaid the segmented image over the original CT - looks great.
Thanks to all for the quick help.
Frank
