POV-Ray : Newsgroups : povray.newusers : Connecting two objects after transformation operations... Server Time
28 Sep 2024 22:15:21 EDT (-0400)
  Connecting two objects after transformation operations... (Message 1 to 3 of 3)
Subject: Connecting two objects after transformation operations...
Date: 13 Feb 2008 06:00:00
Message: <web.47b2cc652e14cb95988f09540@news.povray.org>
Hello,
Let's say I do the following, so what I end up with is two 4-sided CSG objects
somewhere in space.  Now, using cylinders like the ones below, I'd like to
connect the 4 corners of the first CSG object to the 4 corners of the second,
but I can't figure out how to do it.  Any thoughts?
#declare Smooth = finish {specular 0.3 roughness 0.05}
#declare BondWidth = 0.1;
#declare atoms = rgb < 0, 0, 0.5 >;
#declare bonds = rgb < 0.3, 0.3, 0.3 >;
#declare C =
  sphere {
    <0.0, 0.0, 0.0>, 0.4
      pigment {colour atoms}
      finish  {Smooth}
#declare A1  = < 0, 0, 0 >;
#declare A2  = < 1, 0, 0 >;
#declare A3  = < 1 ,1, 0 >;
#declare A4  = < 0, 1, 0 >;
//CSG object 1
union {
  object {
    C
    translate A1
  object {
    C
    translate A2
  object {
    C
    translate A3
  object {
    C
    translate A4
  cylinder {
    A1,
    A2,
    BondWidth
  pigment {colour bonds}
  finish  {Smooth}
  cylinder {
    A2,
    A3,
    BondWidth
  finish  {Smooth}
  cylinder {
    A3,
    A4,
    BondWidth
  finish  {Smooth}
  cylinder {
    A4,
    A1,
    BondWidth
  finish  {Smooth}
rotate SOME_ROTATE_VECTOR
translate SOME_TRANSLATE_VECTOR
//CSG object 2
union {
  object {
    C
    translate A1
  object {
    C
    translate A2
  object {
    C
    translate A3
  object {
    C
    translate A4
  cylinder {
    A1,
    A2,
    BondWidth
  finish  {Smooth}
  cylinder {
    A2,
    A3,
    BondWidth
  finish  {Smooth}
  cylinder {
    A3,
    A4,
    BondWidth
  finish  {Smooth}
  cylinder {
    A4,
    A1,
    BondWidth
  finish  {Smooth}
rotate SOME_OTHER_ROTATE_VECTOR
translate SOME_OTHER_TRANSLATE_VECTOR
Subject: Re: Connecting two objects after transformation operations...
Date: 13 Feb 2008 06:30:26
Message: <47b2d4d2$1@news.povray.org>
"this is me" <nomail@nomail> wrote in message
news:web.47b2cc652e14cb95988f09540@news.povray.org...
> Hello,
> objects
> second,
You can declare a transformation for each rotation/translation pair, then
use your transform both to position the objects and to reposition the
location vectors that you need for the ends of the cylinders. Something like
the following:
#declare MyTransform1 = transform {rotate ... translate ...}
object {... transform {MyTransform1}}
cylinder
{vtransform(MyPoint1,MyTransform1),vtransform(MyPoint1,MyTransform2),MyRadius
Chris B.
Date: 13 Feb 2008 16:30:00
Message: <web.47b3606b67dd78f6e1e1be9d0@news.povray.org>
> the following:
> cylinder
> Regards,
> Chris B.
Excellent!  Just the kind of push in the right direction for which I was
looking.
