POV-Ray : Newsgroups : povray.newusers : Slicing an ellipsoid Server Time
8 Apr 2026 06:00:29 EDT (-0400)
  Slicing an ellipsoid (Message 1 to 10 of 12)
Subject: Slicing an ellipsoid
Date: 3 Nov 2007 04:40:00
Message: <web.472c41bce1cfba5173fa22050@news.povray.org>
I need to generate only a portion of an ellipsoid (a surface, not a solid). The
best way to proceed is by declaring it as a difference between an ellipsoid and
a box? Thanks in advance for help. I am trying to learn by myself but I am
afraid it will require a lot of time, so any help is useful.
Francesco
Subject: Re: Slicing an ellipsoid
Date: 3 Nov 2007 05:53:33
Message: <kurtzlepirate-BF1444.11533303112007@news.povray.org>
In article <web.472c41bce1cfba5173fa22050@news.povray.org>,
> The
> and
> Francesco
or a plane
klp
Date: 3 Nov 2007 06:10:01
Message: <web.472c569770e4ee4e73fa22050@news.povray.org>
> a box?
It seems to me I need to use isosurface. I am studying them :)
Date: 3 Nov 2007 06:23:54
Message: <472c5a4a$1@news.povray.org>
Le 03.11.2007 12:08, Francesco nous fit lire :
>> a box?
Which portion of an ellipsoid do you need ?
If it's a 2D surface, intersection with a couple of parallele plane
should be fine.
Or direct usage of an ellipse.
If it's part of the 3D surface, it obviously depend on which part of
the ellipsoid you want.
CSG is one way.
Parametric another.
And isosurface also... as well as meshes, smooth triangles and so on.
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 3 Nov 2007 06:28:59
Message: <472c5b7b@news.povray.org>
>> a box?
No, why? CSG is the way to go.
	Thorsten
Date: 3 Nov 2007 07:45:01
Message: <web.472c6cd770e4ee4e73fa22050@news.povray.org>
>  Thorsten
It seemed to me CSG was for solid construction, while I need a curve surface
(generated by an ellipse).
Date: 3 Nov 2007 07:49:27
Message: <3hB+HFAW3GLHFw6h@econym.demon.co.uk>
Using a difference makes it look like a solid rather than a surface. Try
clipped_by instead of difference.
Note that you can make an ellipsoid by scaling a sphere.
sphere {0,2
  scale <2,1,0.5>
  clipped_by {box {<-5,-5,-0.2><5,5,0.7>}}
  pigment {rgb 1}
Mike Williams
Gentleman of Leisure
Date: 3 Nov 2007 07:55:00
Message: <web.472c6dda70e4ee4e73fa22050@news.povray.org>
> should be fine.
I would design a curve surface generated by 1/4 ellipse rotating for 10 degrees.
Date: 3 Nov 2007 09:05:54
Message: <6AftvCAs7HLHFwpx@econym.demon.co.uk>
Perhaps something like this
sphere {0,1
  scale <2,1,1>
  clipped_by {plane {-y,0}}
  clipped_by {plane {z,0}}
  clipped_by {plane {-z,0} rotate <0,10,0>}
  pigment {rgb 1}
Mike Williams
Date: 3 Nov 2007 09:50:00
Message: <web.472c899a70e4ee4e73fa22050@news.povray.org>
> sphere {0,1
>   scale <2,1,1>
>   pigment {rgb 1}
That is exactly what I was trying to do! Thanks a lot Mike :)) Simple and
powerful commands. Just a question: you make rotating the clipping plane in
order to exclude some parts to the cut. Is it right?
Francesco
