POV-Ray : Newsgroups : povray.newusers : Mesh and polygons area Server Time
14 Mar 2026 00:14:10 EDT (-0400)
  Mesh and polygons area (Message 1 to 10 of 23)
Subject: Mesh and polygons area
Date: 1 Nov 2007 13:30:01
Message: <web.472a1a292946c4249c17b8500@news.povray.org>
I do not find how to measure area of mesh and polygons. I hope I do not have to
calculate it triangle by triangle. Anyone could help me please?
Subject: Re: Mesh and polygons area
Date: 1 Nov 2007 14:13:08
Message: <472a2544@news.povray.org>
Le 01.11.2007 19:25, Francesco nous fit lire :
Mesh are 3D by nature, you're stuck to the triangle per triangle
solution, IMHO.
Polygon are 2D, and there is a well-known shortcut for them, with an
evaluation on a grid (the finer the grid, the better the precision),
it's just that you have to count the number of intersections from
the grid inside the polygon.
Is it simpler for you ?
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 2 Nov 2007 03:31:51
Message: <472ae077$1@news.povray.org>
Assuming that with a polygone you must know each points coordinates
then the area of triangle is
Area = abs(   (xB*yA - xA*yB)  + (xC*yB -x B*yC)+( xA*yC - xC*yA ) ) /2
news:472a2544@news.povray.org...
have to
> solution, IMHO.
> -- Confucius
Date: 2 Nov 2007 22:00:01
Message: <web.472be3b8881ace7c3bb21de50@news.povray.org>
> > solution, IMHO.
what is that "triangle per triangle" method. Not that I can imagine a need for
the area of a polyhedron.
As for Penelope's 2D function, I get frustrated because triangles can be defined
in 3D space and 2D is almost useless. Hence I tried to simply mentally
extrapolate to 3D and failed.
If you can, post it. When you give up, scroll down. There are 2 methods compared
to functions in triangulation.inc. (tested in script of course)
  ; abs((xB*yA - xA*yB)  + (xC*yB -xB*yC)+( xA*yC - xC*yA)) / 2
  ; extrapolate to 3D ???!!???
alias pntarea {
  ; return $sss-area($vlen($subv($1,$2)), $vlen($subv($2,$3)),
$vlen($subv($3,$1))) = 13405.000015
  ; return $sss-area2(279.72843974111748, 183.3712082089225, 156.24659996300718)
= 13405.000127
  tokenize 32 $1-
  ; = 9 to 3 lens
  var %a = $sqrt($calc((($1 - $4) ^ 2) + (($2 - $5) ^ 2) + (($3 - $6) ^ 2)))
  var %b = $sqrt($calc((($7 - $4) ^ 2) + (($8 - $5) ^ 2) + (($9 - $6) ^ 2)))
  var %c = $sqrt($calc((($1 - $7) ^ 2) + (($2 - $8) ^ 2) + (($3 - $9) ^ 2)))
  var %s = $calc(0.5 * (%a + %b + %c))
  ; return $sqrt($calc(%s * (%s - %a) * (%s - %b) * (%s - %c)))
  ; $pntarea(383 156 0, 645 254 0, 465 289 0) = 13404.999966
  return $calc(0.5 * (%a + %b + %c) * $&
    $calc($sqrt($calc(((%b + %c - %a) * (%c + %a - %b) * (%a + %b - %c)) / (%a +
%b + %c)))) / 2)
  ; = 13404.999974
  ; 2D
  return $calc($abs($calc(($4 * $2 - $1 * $5) + ($7 * $5 - $4* $8) + ($1 * $8 -
$7 * $2))) / 2)
  ; $pntarea(383 156 0, 645 254 0, 465 289 0) = 13405
Date: 3 Nov 2007 00:15:00
Message: <web.472c036d881ace7c3bb21de50@news.povray.org>
seems in my search I use 'area' as opposed to 'volume', doh.
http://www.ecse.rpi.edu/Homepages/wrf/Research/Short_Notes/volume.html
Date: 3 Nov 2007 00:30:00
Message: <web.472c065d881ace7c3bb21de50@news.povray.org>
and that guy is bonkers or what???
" The volume of the pyramid is the area of the base polygon times the distance
from the base plane to the origin. Either of these might be negative."
AND
"Be careful of signs since some tetrahedra should have negative volumes"
a negative volume to me would mean an error!
The Volume of pyramid is [area of the pyramid's base] X [height] X
[1/3], and is expressed in cubic units.
SHEESH
Date: 3 Nov 2007 01:20:01
Message: <web.472c11c0881ace7c3bb21de50@news.povray.org>
> from: [http://www.aaamath.com/B/geo79_x6.htm]
also given 4 3d points, volume of the tetrahedron =
This can be rewritten as a dot and cross product, yielding
    V = \frac { |(\mathbf{d}-\mathbf{a}) \cdot
((\mathbf{d}-\mathbf{b}) \times (\mathbf{d}-\mathbf{c}))| } {6}.
http://en.wikipedia.org/wiki/Tetrahedron
OMG LOL!!!!!!!
tested
alias pyramid_area {
  ; (4 3d pnts)
  return $calc($abs($dotprod($subv($4,$1), $&
         $cross($subv($4,$2), $subv($4,$3)))) / 6)
POV
#macro pyramid_area(A,B,C,D)
  vdot(D-A,vcross(D-B,D-C)) / 6
Date: 3 Nov 2007 01:25:00
Message: <web.472c1324881ace7c3bb21de50@news.povray.org>
#local #result = abs(vdot(D-A,vcross(D-B,D-C))) / 6
  result
ooops
Message: <web.472c1429881ace7c3bb21de50@news.povray.org>
#macro pyramid_volume(A,B,C,D)
sheesh brain fried, see you guys after a month in aruba
Date: 3 Nov 2007 02:04:18
Message: <472c1d72$1@news.povray.org>
Le 03.11.2007 03:58, alphaQuad nous fit lire :
>>> solution, IMHO.
A mesh is just a collection of triangles, and you cannot assert any
properties for the mesh.
(they are not in the same plane, share no common edges... )
Therefore, you have to parse the whole mesh, one triangle at a time,
triangle after triangle!
That formula works (???) only in the plane of the triangle. A
triangle is always 2D.
back to the origin of that formula:
For an ABC triangle, the area is half the length of the cross
product of any two vectors of the triangle from the same origin.
area = | AB x AC | /2 = | BA x BC | /2 = | CA x CB | / 2
with | x | being length of vector x (not abs()!!!), and every AB a
vector.
Therefore the previous formula of penelope2k seems a bit wrong about
the computation...
because the distance we are interested in is only the euclidian
(slow) one!
(square root of the sum of the squared delta)
-- Confucius
