POV-Ray : Newsgroups : povray.newusers : Mesh and polygons area Server Time
13 Mar 2026 13:50:43 EDT (-0400)
  Mesh and polygons area (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Mesh and polygons area
Date: 2 Nov 2007 22:00:01
Message: <web.472be3b8881ace7c3bb21de50@news.povray.org>
"Penelope20k" <pen### [at] caramailfr> wrote:
> Assuming that with a polygone you must know each points coordinates
> then the area of triangle is
> Area = abs(   (xB*yA - xA*yB)  + (xC*yB -x B*yC)+( xA*yC - xC*yA ) ) /2
> > Mesh are 3D by nature, you're stuck to the triangle per triangle
> > solution, IMHO.
what is that "triangle per triangle" method. Not that I can imagine a need for
the area of a polyhedron.
As for Penelope's 2D function, I get frustrated because triangles can be defined
in 3D space and 2D is almost useless. Hence I tried to simply mentally
extrapolate to 3D and failed.
If you can, post it. When you give up, scroll down. There are 2 methods compared
to functions in triangulation.inc. (tested in script of course)
  ; abs((xB*yA - xA*yB)  + (xC*yB -xB*yC)+( xA*yC - xC*yA)) / 2
  ; extrapolate to 3D ???!!???
alias pntarea {
  ; return $sss-area($vlen($subv($1,$2)), $vlen($subv($2,$3)),
$vlen($subv($3,$1))) = 13405.000015
  ; return $sss-area2(279.72843974111748, 183.3712082089225, 156.24659996300718)
= 13405.000127
  tokenize 32 $1-
  ; = 9 to 3 lens
  var %a = $sqrt($calc((($1 - $4) ^ 2) + (($2 - $5) ^ 2) + (($3 - $6) ^ 2)))
  var %b = $sqrt($calc((($7 - $4) ^ 2) + (($8 - $5) ^ 2) + (($9 - $6) ^ 2)))
  var %c = $sqrt($calc((($1 - $7) ^ 2) + (($2 - $8) ^ 2) + (($3 - $9) ^ 2)))
  var %s = $calc(0.5 * (%a + %b + %c))
  ; return $sqrt($calc(%s * (%s - %a) * (%s - %b) * (%s - %c)))
  ; $pntarea(383 156 0, 645 254 0, 465 289 0) = 13404.999966
  return $calc(0.5 * (%a + %b + %c) * $&
    $calc($sqrt($calc(((%b + %c - %a) * (%c + %a - %b) * (%a + %b - %c)) / (%a +
%b + %c)))) / 2)
  ; = 13404.999974
  ; 2D
  return $calc($abs($calc(($4 * $2 - $1 * $5) + ($7 * $5 - $4* $8) + ($1 * $8 -
$7 * $2))) / 2)
  ; $pntarea(383 156 0, 645 254 0, 465 289 0) = 13405
Date: 3 Nov 2007 00:15:00
Message: <web.472c036d881ace7c3bb21de50@news.povray.org>
seems in my search I use 'area' as opposed to 'volume', doh.
http://www.ecse.rpi.edu/Homepages/wrf/Research/Short_Notes/volume.html
Date: 3 Nov 2007 00:30:00
Message: <web.472c065d881ace7c3bb21de50@news.povray.org>
and that guy is bonkers or what???
" The volume of the pyramid is the area of the base polygon times the distance
from the base plane to the origin. Either of these might be negative."
AND
"Be careful of signs since some tetrahedra should have negative volumes"
a negative volume to me would mean an error!
The Volume of pyramid is [area of the pyramid's base] X [height] X
[1/3], and is expressed in cubic units.
SHEESH
Date: 3 Nov 2007 01:20:01
Message: <web.472c11c0881ace7c3bb21de50@news.povray.org>
> from: [http://www.aaamath.com/B/geo79_x6.htm]
also given 4 3d points, volume of the tetrahedron =
This can be rewritten as a dot and cross product, yielding
    V = \frac { |(\mathbf{d}-\mathbf{a}) \cdot
((\mathbf{d}-\mathbf{b}) \times (\mathbf{d}-\mathbf{c}))| } {6}.
http://en.wikipedia.org/wiki/Tetrahedron
OMG LOL!!!!!!!
tested
alias pyramid_area {
  ; (4 3d pnts)
  return $calc($abs($dotprod($subv($4,$1), $&
         $cross($subv($4,$2), $subv($4,$3)))) / 6)
POV
#macro pyramid_area(A,B,C,D)
  vdot(D-A,vcross(D-B,D-C)) / 6
Date: 3 Nov 2007 01:25:00
Message: <web.472c1324881ace7c3bb21de50@news.povray.org>
#local #result = abs(vdot(D-A,vcross(D-B,D-C))) / 6
  result
ooops
Message: <web.472c1429881ace7c3bb21de50@news.povray.org>
#macro pyramid_volume(A,B,C,D)
sheesh brain fried, see you guys after a month in aruba
Date: 3 Nov 2007 02:04:18
Message: <472c1d72$1@news.povray.org>
Le 03.11.2007 03:58, alphaQuad nous fit lire :
>>> solution, IMHO.
A mesh is just a collection of triangles, and you cannot assert any
properties for the mesh.
(they are not in the same plane, share no common edges... )
Therefore, you have to parse the whole mesh, one triangle at a time,
triangle after triangle!
That formula works (???) only in the plane of the triangle. A
triangle is always 2D.
back to the origin of that formula:
For an ABC triangle, the area is half the length of the cross
product of any two vectors of the triangle from the same origin.
area = | AB x AC | /2 = | BA x BC | /2 = | CA x CB | / 2
with | x | being length of vector x (not abs()!!!), and every AB a
vector.
Therefore the previous formula of penelope2k seems a bit wrong about
the computation...
because the distance we are interested in is only the euclidian
(slow) one!
(square root of the sum of the squared delta)
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 3 Nov 2007 03:15:00
Message: <web.472c2d15881ace7c73fa22050@news.povray.org>
Thanks a lot for the assistance to everybody.
> >>>> "Le Forgeron" <jgr### [at] freefr>
> > Mesh...are not in the same plane, share no common edges... )
Don't they share edges? Ok, they are not in the same plane but they share at
least one edge, or not?
>> triangle is always 2D.....
>> the computation...
Calculating area triangle per triangle I can always suppose z=0 (translating and
rotating axis) as triangles are 2D. So I think the formula posted by Penelope20k
is good.
Francesco
Date: 3 Nov 2007 04:25:00
Message: <web.472c3dfb881ace7c73fa22050@news.povray.org>
> and rotating axis) as triangles are 2D. So I think the formula posted by >
> Penelope20k is good.
If I rotate axis the coordinates are different, so I am really confused : ))
May be I could also use Eron's formula, Area= sqrt (s(s-a)(s-b)(s-c)).
Date: 3 Nov 2007 05:27:20
Message: <472c4d08$1@news.povray.org>
Le 03.11.2007 10:23, Francesco nous fit lire :
Illumination is on its way... continue.
It's Heron... and why do you want to compute the length of the side,
when all you need from the 3 vertices are their coordinaates.
Heron's formula is fine when you only have the lengths.
Actually, from a mesh's triangle:
On one hand, two vectors differences, a cross product, three
squaring, a sum and a square root ending with a division.
On the other end, three vectors differences, nine squaring, three
sums, three square root, an intermediate variable (yet a sum and a
division), then three differences, a product of four element, and a
square root.
Of course, you can use Area = 1/4*sqrt( (a+b+c)(a+b-c)(b+c-a)(c+b-a) )
this will avoid the intermediate variable, but the costy part is
computing the length a, b and c anyway!
-- Confucius
