POV-Ray : Newsgroups : povray.newusers : Transparency one way only Server Time
8 Apr 2026 08:13:06 EDT (-0400)
  Transparency one way only (Message 1 to 5 of 5)
Subject: Transparency one way only
Date: 11 Oct 2007 16:10:01
Message: <web.470e826a61c90da3ccd3f470@news.povray.org>
Working on a model of a room and somtimes I would like to take a step back
to see more of the room, but then of course walls (povray boxes) get in the
way. Is there a way to make an object, such as a box, transparent but only
if one looks outside in, i.e. from one direction.
Many thanks in advance,
Pahidla
Subject: Re: Transparency one way only
Date: 11 Oct 2007 16:21:51
Message: <470e85df$1@news.povray.org>
"Pahidla" <dol### [at] yahoocom> wrote in message
news:web.470e826a61c90da3ccd3f470@news.povray.org...
> Hi,
> the
    Hi Pahidla
     As far as I know, no, there isn't a way to do this. What you can do
however, is to give your boxes, (walls), a 'no_image' statement in your
texture, like below, and then pan back out:
    OBJECT {
    [OBJECT_ITEMS...]
    no_image
     You may also want to use 'no_reflection' and 'no_shadow' if you so
wish.
     See: http://www.povray.org/documentation/view/3.6.1/328/
     ~Steve~
> Pahidla
Date: 11 Oct 2007 16:26:02
Message: <470e86da@news.povray.org>
  Using "no_image" in the wall you want to "remove", as suggested, is a
good way.
  Another possibility, if your wall is not a box but a planar surface
(eg. created as a plane or as a polygon) is that you can give it an
interior_texture besides the regular texture. This way you can make
one side of the wall transparent while the other is opaque.
Date: 11 Oct 2007 16:26:46
Message: <470e8706$1@news.povray.org>
Le 11.10.2007 22:07, Pahidla nous fit lire :
> Hi,
You need a patch to do that.
A long time ago, when povray license was understandable, I did that
patch... for 3.1g
it was easy, just a kind of CSG construct (think union) which filter
in All_..._Intersections so that the dot product of the normal and
ray had to be positif to keep a child's intersection.
Works fine... box, cone, sphere, all only showing their inner side,
never their outer side, even in mirror!
Now, if someone can explain how to distribute such patch within the
3.5/3.6/3.7 license, please be my guest and I might consider do that
again.
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 11 Oct 2007 17:15:08
Message: <470e925c@news.povray.org>
  No you don't.
