POV-Ray : Newsgroups : povray.newusers : Simultaneous views Server Time
17 Aug 2025 05:58:58 EDT (-0400)
  Simultaneous views (Message 1 to 6 of 6)
Subject: Simultaneous views
Date: 3 Oct 2007 23:15:01
Message: <web.47045a323e5a699d3ccd3f470@news.povray.org>
I know that PovRay was not historically meant as a GUI, but is it possible
to generate, say, 4 simultaneous views of the scene with different camera
settings?
Thank you.
Pahidla
Subject: Re: Simultaneous views
Date: 3 Oct 2007 23:25:15
Message: <47045d1b$1@news.povray.org>
Pahidla nous apporta ses lumieres en ce 2007/10/03 23:12:
> Hi,
> settings?
> Thank you.
> Pahidla
Not directly. It can be possible using some tricks to create an image where the
same scene apears several times from different point of view, but it's far from
obvious.
   If it weren't for pickpockets, I'd have no sex life at all.
   	Rodney Dangerfield
Date: 4 Oct 2007 00:25:01
Message: <web.47046af2d920753e3ccd3f470@news.povray.org>
> > Hi,
> > settings?
> > Thank you.
> > Pahidla
> obvious.
> Alain
>     Rodney Dangerfield
I'm happy to hear suggestions!
Date: 4 Oct 2007 01:10:00
Message: <web.47047493d920753e6dde0d470@news.povray.org>
easiest way: use MegaPOV, have some boxes far away from your "real" scene
which have
pigment{ camera_view{ /* camera-items */ ... } }
and your "real" camera looks_at those blocks, of course ...
This does not work under all circumstances, but I find it useful when
constructing new objects to be able to test-render them in on go and have
different views in the same picture. Could do that by using rotated and
translated copies, but they tend to influence each other (shadows and such)
Happy rendering
Karl
Date: 4 Oct 2007 19:00:54
Message: <470570a6@news.povray.org>
Hash: SHA1
> settings?
How about a four-frame animation with a moving camera?
William Tracy
You know you've been raytracing too long when Intel's R&D department
limits you to two calls a day.
    -- John VanSickle
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHBXClcCmTzQ++ZncRAuiDAJ4rOwzKm+A2y11um34JsXtx/mGZ6wCbB8f/
QUyIligIrOAZasG7DHiQgWE=
=zyxh
-----END PGP SIGNATURE-----
Date: 5 Oct 2007 08:12:09
Message: <47062a19@news.povray.org>
Desk.pov in the advanced scenes folder does something similar.  Look at
the "#declare Picture" block (although I probably would have used
frame_number rather than clock).
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
