I'm new to POV, and I'm trying to make a camera follow a certain path. For a
total time of 5, I want the camera to spend 0<t<1 at a certain point, then
move along a specific circular path over time 1<t<2, and then remain at the
end
point of this path for t>2. This is the code i wrote for it, but it doesn't
seem to work. I'm sure I'm missing someting stupidly obvious, but could
someone give me a hand. Either de-bug or a pointer in the right direction
would be helpful.
Thx,
OpalPlanet
//declare variables for camera motion
#declare loopcount = 0;
#declare X = 0;
#declare Y = 0;
#declare Z = -3.5;
#declare Ystep = -.01375;
#declare Zstep = -.0125;
#if (clock <= 1)
location <0,0,-3.5 >
look_at <0,0,0>}
#else #if (clock <= 2)
//move camera coords
#while loopcount <= 200
Y = Y + Ystep;
Z = Z + Zstep;
#end // end while
location <0, Y, Z >
look_at <0,0,0>
#else
camera{
location<0,-2.75,-1>
look_at<0,0,0>
//end cameras
> end
> would be helpful.
> Thx,
> OpalPlanet
> #declare X = 0;
> #declare Y = 0;
> #declare Z = -3.5;
> #if (clock <= 1)
> camera {
> look_at <0,0,0>}
> Y = Y + Ystep;
> Z = Z + Zstep;
> #end // end while
> camera {
> location <0, Y, Z >
> look_at <0,0,0>
> #else
> camera{
> look_at<0,0,0>
> //end cameras
It looks like you're missing some parenthesis next to your #while statement,
and some #end statements. You also forgot to increment your counter. It
doesn't work to use multiple #else's but there is a handier thing you can
use instead:
#switch()
#case() #break
#case() #break
#case() #break
Untested but it'd look something like this:
#declare X = 0;
#declare Y = 0;
#declare Z = -3.5;
#declare Xstep = 0;
#declare Ystep = -2.75;
#declare Zstep = -1;
#declare MyClock = 5*clock; //A clock that goes from 0 to 1 is good for
compatibility.
#switch (MyClock)
#case(MyClock <=1)
#declare Cam_Location = <0,0,-3.5>;
#declare Cam_Look_At = <0,0,0>;
#break
#case(MyClock <= 2) //testing for <= 1 is covered by previous #case
<X+Xstep*(MyClock-1),Y+YStep*(MyClock-1),Z+Zstep*(MyClock-1)>;
#break
#case(MyClock > 2)
#declare Cam_Location = <0,-2.75,-1>;
#break
#end //end #switch (MyClock)
camera{
location Cam_Location
look_at Cam_Look_At
> a
> the
> end
> doesn't
> would be helpful.
> #declare X = 0;
> #declare Y = 0;
> #declare Z = -3.5;
> #if (clock <= 1)
the clock variable defaults to 0..1,
this can be changed in the ini files
or with command line commands,
if you've done that great, otherwise use 1/5 instead...
> camera {
> look_at <0,0,0>}
After holding still you want the
camera to move for 1/5 of the animation.
So just set up another variable for clock
durring that time...
#else
#local My_clock = clock-1/5;
or
#local My_clock = clock - 1;
> Y = Y + Ystep;
> Z = Z + Zstep;
> #end // end while
This while loop executes the whole loop, but why?
just leave that out, the animation loop will re-parse
the whole scene for every frame with a different
clock value.
> camera {
> location <0, Y, Z >
> look_at <0,0,0>
Y an Z have the same value every time...
try something like...
#local CLOC = vrotate(<0,0.75,0>;90*My_clock*y)+<0,-2.75,0>;
location CLOC
look_at <0,0,0>
You might also look into using a spline, that might make lining
up the start and stop of your movements line up easier
if you decide to change it later.
> #else
> camera{
> look_at<0,0,0>
> //end cameras
My example would have needed a #switch(1) at the start instead of
#switch(MyClock), but better yet, leave the #switch(MyClock) and replace
the #case() statements with, for example, statements like #range(0,1).
It worked even without the changes!
Thanks,
OpalPlanet
