POV-Ray : Newsgroups : povray.newusers : Ideas on how to accomplish this effect needed... Server Time
14 Mar 2026 05:27:11 EDT (-0400)
  Ideas on how to accomplish this effect needed... (Message 1 to 4 of 4)
Subject: Ideas on how to accomplish this effect needed...
Date: 2 May 2007 00:15:01
Message: <web.4638100b40b8ee6c7a9334df0@news.povray.org>
I am looking for help on an effect (or maybe it's two effects)
1. I want to create a 3D image which looks like transparencies stacked one
on top of the other. Each transparencey will have an image or text on it
(via image_map I think).   I can use Box{} to simulate the sheet with
dimensions of the sheet and z dimension being thickness (i.e. a very thin
box).  If I put several on top of each other will I need to increase the
maxtrace value?
2. Is it possible to determine where on the Box{} the image is placed?
Subject: Re: Ideas on how to accomplish this effect needed...
Date: 2 May 2007 03:00:52
Message: <46383724$1@news.povray.org>
web.4638100b40b8ee6c7a9334df0@news.povray.org...
> maxtrace value?
If you use boxes, the rays will cross 2 surfaces per box. Why not use planes
or pairs of triangles (if you want edges) which have no thickness at all
beeing single face objects? You certainly will need to increase
max_trace_level which default value is5.
You can apply transformations to you pigment.
Here is an exemple of texture :
   texture
      pigment
         image_map
            jpeg   "You_image.jpg"
            once // image displayed only once, no tiling!
            filter all 1.0 // filter transparency  as coloured filter , you
can use transmit as well (or any mixed amount of both) as a thin fabric
behaves with light
         translate    <-0.2, -0.5, 0.0>  // here a translation but you can
scale and rotate as usual
      finish
         ambient 0.0
         diffuse 0.8 // diffuse value higher than 0.6 default value to keep
a contrasted image
Marc
Date: 3 May 2007 21:55:02
Message: <web.463a916db7cab9247a9334df0@news.povray.org>
> > maxtrace value?
>    texture
>       pigment
>          image_map
> behaves with light
>       finish
>          ambient 0.0
> a contrasted image
> Marc
A) I would have thought the translate operation needed to be within the
brackets for the image_map? (I am not unfamiliar with programming, just
POV-Ray). As written it seems to translate the pigment as opposed to the
image.
B) Won't the image fill the entire plane? Sometimes I want the image to be
only a small part of the "transparency"
But, thanks for the tips - I will try to use some of them and see what
results I get.
Date: 4 May 2007 02:51:49
Message: <463ad805@news.povray.org>
web.463a916db7cab9247a9334df0@news.povray.org...
> image.
Yes transformations are applied to the pigment. Is it a problem?
If you use the keyword "once", the image_map fills a <0,0,-infinite> to
<1,1,infinite> square section  before transformations. what you see (what
POVRay traces) is the intersection of the plane with this infinitely thick
square.
If you don't use "once", the map is tiled edge to edge in both x and y
directions
> results I get.
That's the best way :-)
Marc
