![](/i/fill.gif) |
kike nous apporta ses lumieres en ce 05-03-2007 05:00:
> I finally solved the problem. It was (as I suspected) a problem in between
> relative position of light, camera and absorbing object. But now I have
> another problem. Mesh supports absorption but I thought I could simulate
> smoke with a mesh and now I see it is not possible. Let me explain this.
> If you make an absorbing mesh, absorption will fix to the mesh but you will
> not see the cool effect of noisy smoke in the edges. To see this cool
> effect you have to define a density pattern (for example a spherical
> density pattern) smaller than the mesh with some turbulence. But then what
> you actually see is that the absorption has the same shape for a mesh, a
> box or a sphere. So doesnt seem to be a good idea to sculpt a mesh with the
> shape of a smoke column and then expect absorption to do the rest. It is
> better to use the trick of using several spheres (as the smoke plug-in I
> have seen).
You can still use your mesh and fill it with several media, that way, they add up.
Wars are not paid for in wartime, the bill comes later.
Benjamin Franklin
![](/i/fill.gif) |
