POV-Ray : Newsgroups : povray.newusers : Glow effect problem Server Time
9 Apr 2026 04:03:33 EDT (-0400)
  Glow effect problem (Message 11 to 13 of 13)
Subject: Re: Glow effect problem
Date: 8 Feb 2007 11:55:00
Message: <web.45cb55dc12efcd2eec8e142c0@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> wrote:
> Color maps fade from 0 to 1 linearly, but the spherical pattern
> is going along a curve. You can tweak the location and color
> to suit what you want in the color map. The colors are added
> to the background color, white tends to saturate...
> However, the spherical pattern is located at the origin, to move
> it you need to define it at the origin, and then translate it.
> You won't see the spherical pattern if you just place the container
> object elsewhere.
> This is correct:
> sphere {<0,0,0>,1 hollow material{glow} translate <0,1,0>}
> This is wrong:
> sphere {<0,1,0>,1 hollow material{glow} }
I'm sorry, I don't understand how that applies. Perhaps I explained badly.
In an empty test scene, the glow effect fades smoothly from the center to
the edge. The code follows:
light_source {<2,0,0> color White
   looks_like{
   sphere{<0,0,0>,1
     hollow
      material{
       texture{
        pigment{Clear}
    interior{
    media{
      emission 0.75
      scattering {1, 0.5}
      density{
        spherical
        color_map{
          [0.0 rgb <0,0,0>]
          [0.5 rgb <1,1,1>]
          [1.0 rgb <1,1,1>]
That works perfectly. The glow in my main scene however, uses the same code
but does not fade. The different code segments follow:
light_source {
    <39.167,9.901,-40.446>
     color rgb <1,1,1>
And    interior{
        media{
         emission 0.75
         scattering {1, 0.5}
         density {
           spherical
           color_map{
            [0.0 rgb <0,0,0.5>]
            [0.5 rgb <.8,.8,1>]
            [1.0 rgb <1,1,1>]
I hope that clears this up! Thanks,
    Michael
Date: 8 Feb 2007 15:01:30
Message: <45cb819a@news.povray.org>
With media you are modeling a sphere
that is filled with a gas that varies in
color...
The final color depends on the background,
for example a red glow will appear purple
against a blue sky.
You can keep tweaking the size of the
sphere and the color map until you get
somewhat what you'd like.
In the real world, bright spots come from
a lens distortion effect at your eye.
Chris Colefax's include file models this by
placing a 2 dimensional disc with an
appropriate semi-transparent texture
near the camera. Some values are passed
by #declare to set the apparent location
of the glow, etc. In general for the type
of situation you are describing it would
be the better approach.
http://www.geocities.com/ccolefax/lenseffects.html
There's nothing keeping you from modeling
both the gas and the lens effect.
Date: 8 Feb 2007 23:50:00
Message: <web.45cbfc6612efcd2ed646235f0@news.povray.org>
I think I understand. Thanks for your help!
Michael
