POV-Ray : Newsgroups : povray.newusers : about media Server Time
12 Oct 2025 19:59:54 EDT (-0400)
  about media (Message 1 to 4 of 4)
Subject: about media
Date: 1 Jan 2007 05:35:01
Message: <web.4598e3a2fb205ac747d3ae5e0@news.povray.org>
Hi!
Im doing a dark alleyway scene, and im experimenting with media a bit...
http://img132.imageshack.us/img132/4606/alley2ru4.jpg
want these "clouds" that appear, probably as a result of the density
thing..
If you got any tips, please help me.
/rush
----------the media code-----------
media {    // atmospheric media sample
  intervals 10   //10
  scattering { 1, 0.05 extinction 0.5  }
  density {
        bumps
        frequency 2            // <- add this line
    color_map {
      [0.00 color Gray20]
      [0.50 color Gray40]
      [1.00 color Gray20]
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  ratio 0.9 //0.9
Subject: Re: about media
Date: 1 Jan 2007 06:45:00
Message: <web.4598f3794c020cda47d3ae5e0@news.povray.org>
Well... setting all the colors in the color map to the same did the trick...
Probably not the A+ way to do it, but who can tell on the outcome.. ;)
Date: 1 Jan 2007 12:00:30
Message: <45993e2e@news.povray.org>
RusHHouR nous apporta ses lumieres en ce 01-01-2007 05:34:
> Hi!
> thing..
> /rush
>   intervals 10   //10
>   density {
>         bumps
>     color_map {
>       [0.00 color Gray20]
>       [0.50 color Gray40]
>       [1.00 color Gray20]
>   samples 1, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9 //0.9
One thing that you can do, is to contain your media in some container. In your
case, a cone with the sumit slightly over the light and a bit larger than the
light's cone would probably do nice.
As a side bonus, it would render faster as the media will now only be computed
where it's visible.
cone{<0,10,0>,0,0,Light_radius+0.1//adjust dimentions and translate as needed
	pigment{rgbt 1}//perfectly transparent
	hollow//so it can contain the media. It's the only use of that keyword.
	interior{Your_media}
If you're ever about to be mugged by a couple of clowns, don't hesitate - go for
the juggler.
Date: 2 Jan 2007 16:00:01
Message: <web.459ac7594c020cda47d3ae5e0@news.povray.org>
> > Hi!
> > thing..
> > /rush
> >   intervals 10   //10
> >   density {
> >         bumps
> >     color_map {
> >       [0.00 color Gray20]
> >       [0.50 color Gray40]
> >       [1.00 color Gray20]
> >   samples 1, 10
> >   confidence 0.9999
> >   variance 1/1000
> >   ratio 0.9 //0.9
> where it's visible.
> Alain
> the juggler.
Its not harder than that?!
Kewl! And rendering times _were_ getting outta hand...
Thanks!
