POV-Ray : Newsgroups : povray.newusers : simulating cracks in surface using normals Server Time
16 Sep 2025 11:36:40 EDT (-0400)
  simulating cracks in surface using normals (Message 1 to 8 of 8)
Subject: simulating cracks in surface using normals
Date: 25 Oct 2006 08:35:00
Message: <web.453f58fd2a0eadd4109a9bf40@news.povray.org>
As in the previous post (1. photorealistic play-doh 2. round off at csg
edges) I am trying to create a photorealistic clay surface. In addition to
the bozo normal pattern which gives the clay a smooth moulded look, I want
to add some cracks here and there. I guess something can be done with
layered textures:
texture {MouldedLook}
texture {AddedCracks}
but every time I end up influencing the MouldedLook texture also at places
where there's no crack. Can someone help me on:
1. how to simulate a normal with random cracks here and there (so preferably
without a bump_map)
2. how to declare the texture in such a way that it doesn't mess with the
underlaying MouldedLook texture at places where there's no crack?
Subject: Re: simulating cracks in surface using normals
Date: 25 Oct 2006 09:52:36
Message: <453f6c24$1@news.povray.org>
well , one way is to create your MouldedLook texture and Cracks texture
separatley ..
Then use an average statement by pounding your texture .. this is done like
that
Texture {average
        texture_map {
            [weight_texture1   MouldedLook]
            [weight_texture2    Cracks]
news:web.453f58fd2a0eadd4109a9bf40@news.povray.org...
> Hi,
> layered textures:
preferably
> without a bump_map)
Date: 25 Oct 2006 12:00:01
Message: <web.453f89f584a00c02109a9bf40@news.povray.org>
Thanks! I've tried using average; the only problem is that it also averages
the textures at the points where there's no crack. So for example if both
textures have equal weights, the bozo strength of the MouldedLook is
divided by 2. This works fine if I use a bump_map for the crack with the
everything but the crack filled with black pixels; in this case the Crack
texture returns the simple uniform color that is part of both textures. If
I then multiply the bozo in MouldedLook by 2 I get my original texture
back.
However, I would like to use a more random pattern instead of a repeating
crack picture, and was unable to create a normal which returns some random
cracks with a strong normal but leaves everything else unaltered like in
the bump_map. Is there a good way to make such a pattern? Maybe with some
agate or marble pattern like in a pigment with a color_map like the example
on http://library.thinkquest.org/3285/language/pigment.html#agate . Can a
similar thing be done with a normal?
Date: 25 Oct 2006 13:15:01
Message: <web.453f9b7184a00c02c150d4c10@news.povray.org>
"Toon" <nomail@nomail> wrote:
> Hi,
> back.
try crackle with a user defined slope_map, you may also need to play with
the form values though the default should be adequate.  See the docs for
more help on the crackle pattern and slope_map.
-tgq
Date: 25 Oct 2006 23:41:42
Message: <45402D24.3080008@joplin.com>
Toon wrote:
> Hi,
> back.
Pov reference 2.3.4.5  Working With Normal Maps should do the trick.
Date: 26 Oct 2006 12:15:00
Message: <web.4540ddd084a00c02109a9bf40@news.povray.org>
> -tgq
Thanks for all the tips, after playing around with crackle and slope_maps, I
can get someting that looks a little like what I want, but not entirely. I
can't seem to get any really deep cracks. Maybe someone can tell me what I
am doing wrong? I'd like to create a scaleable Cracks normal with
AmountOfCracks, CracksDepth and CracksLength settings. Anybody any idea?
(Any other ideas to get the clay more realistic are also welcome!)The code
for some claylike spheres that illustrate the problem is the following:
camera {look_at <0.0,0,0>
        location <-5 , 0.0 , -50>
global_settings {radiosity {}}
light_source{<1000,1000,-1000>  color rgb 0.5}
sky_sphere {pigment{color rgb 2}}
plane { y, -6 texture {pigment {color rgb <1,1,1>} finish {ambient 0.1
diffuse 0.2}}}
plane {z, 1000 pigment {color rgb 0.5}}
#declare MouldedLook=normal{bozo -8 scale 3 }
#declare Cracks=normal{crackle
                       scale 10
                       turbulence <0.7,0.5,0>
                       slope_map {[0, <-1,0>]
                                  [0.01 <-1,0>]
                                  [0.01 <0,0>]
                                  [1 <0,0>]
#declare NoNormal=normal{bumps 0.00001}
#declare MouldedCracks=normal{average
normal_map{[1,MouldedLook][1,Cracks][-1,NoNormal]}}
sphere { <0,0,0>,6 texture{pigment{color Orange} normal{Cracks} finish
{ambient 0 diffuse 0.6}} translate <-10,0,0> }
sphere { <0,0,0>, 6 texture{pigment{color Orange} normal{MouldedLook}}
finish {ambient 0 diffuse 0.6}translate <0,0,0> }
sphere { <0,0,0>,6 texture{pigment{color Orange} normal{MouldedCracks}}
finish {ambient 0 diffuse 0.6} translate <10,0,0> }
Date: 26 Oct 2006 14:25:00
Message: <web.4540fd0e84a00c02c150d4c10@news.povray.org>
> > -tgq
> diffuse 0.2}}}
>                        scale 10
>                                   [0.01 <-1,0>]
>                                   [0.01 <0,0>]
>                                   [1 <0,0>]
You can try adding a float value behind crackle ("crackle c"), you can use
this to scale the apparent depth
However, the normals are just surface normal and faked, so there will be
some limitation on how deep they can actually appear, especially with
radiosity on.  Looks like you have the general idea now though, keep at it.
-tgq
Date: 27 Oct 2006 06:44:37
Message: <4541e315@news.povray.org>
"Toon" <nomail@nomail> wrote in message
news:web.4540ddd084a00c02109a9bf40@news.povray.org...
> I
> ... snip ...
Hi Toon,
As Trevor mentioned, the normals you apply are just faking it.
One way of faking it a little bit more is to overlay your own darkening of
the cracks using a colour pattern.
The 'NewCracks' texture below uses the crackle as a pigment instead of a
normal.
'NewCracks2' uses a slightly smaller crackle as a pigment and combines it
with the original crackle normal to emphasise the highlights on the rims. It
also takes the 'darkened' Orange color right down to 0 to give a really deep
dark centre.
Hope this helps.
Chris B.
        location <-5 , 0.0 , -20>
diffuse 0.2}}}
                       scale 10
                                  [0.01 <-1,0>]
                                  [0.01 <0,0>]
                                  [1 <0,0>]
#declare NewCracks = texture {
  pigment{
    crackle
    scale 10
    color_map {
      [0    rgbt 0.8*Orange]
      [0.0003 rgbt 0.5*Orange]
      [0.01 rgbt 0.8*Orange]
      [0.01 rgbt Orange]
      [1    rgbt Orange]
  normal{bozo 8 scale 3}
#declare NewCracks2 = texture {
  pigment{
    crackle
    scale 10
    color_map {
      [0      rgbt 0.8*Orange]
      [0.0003 rgbt 0*Orange]
      [0.009  rgbt 0.8*Orange]
      [0.009  rgbt Orange]
      [1      rgbt Orange]
  normal{average normal_map{[1,MouldedLook][1,Cracks][-1,NoNormal]}}
sphere { <0,0,0>, 6 texture{NewCracks}
sphere { <0,0,0>,6 texture{NewCracks2}
