POV-Ray : Newsgroups : povray.newusers : Creating Polyhedra with different colors for the faces Server Time
20 Dec 2025 21:08:11 EST (-0500)
  Creating Polyhedra with different colors for the faces (Message 1 to 10 of 10)
Subject: Creating Polyhedra with different colors for the faces
Date: 28 Mar 2006 09:55:00
Message: <web.44294e1a3cedcf6deb0084670@news.povray.org>
first of all, i'm very new to Pov Ray ;)
Well, I'm trying to render Polyhedra and want the faces to have different
colors.
At the moment I render my polyhedra as intersection of halfspaces, which
works fine.
The question is, how can I give each Face a certain color?
Can someone help?
Thanks in advance,
Philip
Subject: Re: Creating Polyhedra with different colors for the faces
Date: 28 Mar 2006 10:10:09
Message: <442951d1@news.povray.org>
> works fine.
  I don't know what a halfspace is, but if you give each one its own
pigment, it should do what you want.
Date: 28 Mar 2006 10:45:00
Message: <web.44295906246859f5e8c60c9f0@news.povray.org>
> > works fine.
since I use the intersection command with planes, i can't give each plane
it's own color(what would solve my problem, i think).I've tried that, and
got back an error :(
thanks anyway
Date: 28 Mar 2006 10:55:00
Message: <web.44295c25246859f581d8be9d0@news.povray.org>
"Philip" <Phi### [at] yahoocom> wrote:
> Hi,
> thanks anyway
And what did the error say? It should work as Warp suggested
intersection {
  plane {
    pigment { ... }
  plane {
    pigment { ... }
  plane {
    pigment { ... }
Regards Roman
Date: 28 Mar 2006 11:15:01
Message: <web.4429606e246859f5e8c60c9f0@news.povray.org>
Well, it DID work,
I tried to write a comma between the distance and the pigment command.
Sorry for bothering.
Thanks a lot,
Philip
Date: 29 Mar 2006 15:39:46
Message: <442af091@news.povray.org>
>> Hi,
Why not use a difference to obtain the results you want?
Using your sample:
> [snip]
difference {
box {
     pigment { ... } // doesn't matter what
plane {
     pigment { ... }
   plane {
     pigment { ... }
   plane {
     pigment { ... }
I didn't try it, it's a thought.
> intersection {
>   plane {
>     pigment { ... }
>   plane {
>     pigment { ... }
>   plane {
>     pigment { ... }
> Regards Roman
Bye
Txemi Jendrix.
Povray and CG: www.txemijendrix.com
Music: www.losmiercoles.net
Date: 29 Mar 2006 17:00:00
Message: <web.442b02c2246859f576d9909d0@news.povray.org>
This would work as well and leads to the same result but your version needs
one unnecessary object more (the box) and is therefore slightly slower.
Shouldn't play a role with such a simple object though.
Regards Roman
Date: 30 Mar 2006 02:46:47
Message: <442b8ce7@news.povray.org>
  Why? What would be the advantage?
Date: 31 Mar 2006 08:33:30
Message: <442d2fa9@news.povray.org>
This is what Philip told us about his problem:
"since I use the intersection command with planes,
i can't give each plane it's own color(what would
got back an error :("
I was trying to give him an alternative.
I know there is no advantage.
Txemi Jendrix.
Date: 31 Mar 2006 08:34:19
Message: <442d2fda@news.povray.org>
> needs one unnecessary object more (the box) and is therefore slightly
> slower. Shouldn't play a role with such a simple object though.
> Regards Roman
Look my response to Warp
Txemi Jendrix.
