POV-Ray : Newsgroups : povray.newusers : Filling a cylinder Server Time
20 Nov 2025 00:27:40 EST (-0500)
  Filling a cylinder (Message 1 to 5 of 5)
Subject: Filling a cylinder
Date: 16 Mar 2006 13:50:00
Message: <web.4419b2fd162ba78a8d202af60@news.povray.org>
How can I create a cylinder with a solid filling? I tried to use CSG and for
example when I intersect two cylinders I get only the intersection of the
surfaces.
Raffaele
Subject: Re: Filling a cylinder
Date: 16 Mar 2006 14:14:34
Message: <4419b91a$1@news.povray.org>
news:web.4419b2fd162ba78a8d202af60@news.povray.org...
for
> surfaces.
> Cheers
> Raffaele
Maybe you are stumbling on a coincident surfaces issues, make one of the
cylinders slightly longer than the other.
Marc
Date: 16 Mar 2006 23:49:37
Message: <441a3fe1$1@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:4419b91a$1@news.povray.org...
> for
>> surfaces.
If it is not something like Marc said, which would look like a pipe with
open ends, and instead the idea is to fill the inside of a transparent
object then you will need to use 'media'.
Other than that, using 'intersection' would only show a single surface of
where the two cylinders intersect the same space anyhow. Maybe you wanted a
'difference', where one remains and the other is subtracted away. If that
were done, same applies again as Marc said except when one is inside the
other you would get a thickened tube or pipe.
Also, might be of great help to know a little more about the actual POV
script you're trying to do.
Date: 19 Mar 2006 22:32:20
Message: <441e2244@news.povray.org>
> surfaces.
  Could you be more specific on what is the effect you are trying to
achieve?
  How are you seeing that they are "only surfaces"? What is it that you
would want to see instead?
Date: 20 Mar 2006 03:09:35
Message: <441e633f@news.povray.org>
news:441e2244@news.povray.org...
for
the
> > surfaces.
> achieve?
I tested it:
If you intersect 2 cylinders with coincident ends, you get an open ends
'lemon' shaped section.
I think he wants a closed shape, so he can fix it by making one of the
cylinders longer .
Marc
