POV-Ray : Newsgroups : povray.newusers : Elliptical Torus Server Time
13 Oct 2025 07:03:49 EDT (-0400)
  Elliptical Torus (Message 1 to 10 of 13)
Subject: Elliptical Torus
Date: 28 Feb 2006 19:45:00
Message: <web.4404ee5087a86c85c61d550e0@news.povray.org>
Hello All
Is it possible to create an elliptical torus with a varying major diameter
and a constant minor diameter?
  Thanx,
  tgl
Subject: Re: Elliptical Torus
Date: 1 Mar 2006 06:30:00
Message: <web.4405855061f3c539f37ab23e0@news.povray.org>
"tgl" <aub### [at] sympaticoca> wrote:
> Hello All
>   Thanx,
>   tgl
it should be possible with isosurfaces. see e.g.
http://www.econym.demon.co.uk/isotut/variable.htm
Another possibility would be to approximate the surface with a spheresweep,
see 2.4.1.10 Sphere Sweep
http://www.povray.org/documentation/view/3.6.1/284/
Regards Roman
Date: 1 Mar 2006 14:36:52
Message: <kurtzlepirate-C257F1.20365101032006@news.povray.org>
In article <web.4405855061f3c539f37ab23e0@news.povray.org>,
> > Hello All
> >   Thanx,
> >   tgl
> Regards Roman
as roman say, i think using sphere sweep is a right solution. computing
points of an ellipse is easy.
klp
Date: 1 Mar 2006 19:45:00
Message: <web.44063f9261f3c5391c6902970@news.povray.org>
> Hello All
>   Thanx,
>   tgl
or approximate it by connecting spheres and cylinders. May render faster?
H
Date: 1 Mar 2006 20:40:01
Message: <web.44064c4c61f3c539a88bea740@news.povray.org>
> Hello All
>   Thanx,
>   tgl
 I was looking to use the torus object statement and incorperate a
mathematical formula to create an oval shape of what ever dimensions and
keep the torus cylinder itself a constant diameter. Scaling a torus doesn't
work.
 Anyone know a formula that may work?
 Again thank you,
 tgl
Date: 2 Mar 2006 03:16:54
Message: <mdb6oHAXmqBEFwHS@econym.demon.co.uk>
>> Hello All
>>   Thanx,
>>   tgl
I've tried to achieve the effect by modifying the "surface of
revolution" isosurface technique, but everything that changes the major
diameter seems to have a side effect that changes the shape of the minor
cross section.
Mike Williams
Gentleman of Leisure
Date: 2 Mar 2006 05:00:00
Message: <web.4406c1fa61f3c539f37ab23e0@news.povray.org>
does this work for you?
  location <-5,15,-10>
  look_at 0
  angle 45
light_source {
  <-5,15,-10>
  rgb 1
#local a = 5; //semimajor axis
#local b = 3; //semiminor axis
#local r = .5; //minor radius
#local n = 20;//number of spheres/accuracy of object
sphere_sweep {
  cubic_spline
  n+3,
  #local i=0;
  #while(i<=2*pi*(1+2/n))
    <a*sin(i),0,b*cos(i)>, r
    #local i=i+(2*pi/n);
  pigment { rgb y }
  finish { phong 1 }
Regards Roman
Date: 2 Mar 2006 17:50:00
Message: <web.4407760b61f3c5399fea01560@news.povray.org>
> camera {
>   look_at 0
>   angle 45
> light_source {
>   <-5,15,-10>
>   rgb 1
> sphere_sweep {
>   cubic_spline
>   n+3,
>   #local i=0;
>   #end
>   pigment { rgb y }
>   finish { phong 1 }
> Regards Roman
Tried the above and as is, it looks good but then I tried the following
variation...
  location <0,0,-10>
  look_at 0
light_source {
  <-5,15,-10>
  rgb 1
sphere_sweep {
  cubic_spline
  n+3,
  #local i=0;
  pigment { rgb y }
  finish { phong 1 }
  rotate <-90,0,0>
 Is there some kind of distortion happening here or am I seeing things. I
really need an accurate and consistant shape.
 tgl
Date: 2 Mar 2006 19:05:00
Message: <web.440786bb61f3c5392bb58dc50@news.povray.org>
Hi!
I worked on the problem and I posted in p.b.i + p.b.s-f a solution with
sphere_sweep, and also with a blob (fast render) with a constant behaviour
(I think ..). Your problem might come from the use of the parametric form
of an ellipse, which gives non-constant spacing between samples on the
perimeter from regular parametric values, or/and perhaps from the use of too
few control points in the spline.
The blob macro I posted uses also the parametric equation, but travels along
the perimeter by oversampling, an drops a blob element every constant
spacing, giving quite good results. I hope thi will help, and I am sure
that what I did can be very much improved.
    Bruno
Date: 3 Mar 2006 01:36:43
Message: <MZzwpFA2M+BEFwDD@econym.demon.co.uk>
It's an optical illusion caused by the fact that you see more shadow on
the horizontal parts, and the shadow is the same colour as the
background.
If you run that test with a white background the illusion goes away and
you can see that the real shape is consistent.
background {rgb 1}
You can easily check the accuracy by adding some spheres with a slightly
larger radius along the ellipse, and observing that they all fit
properly.
  location <0,0,-10>
  look_at 0
light_source {
  <-5,15,-10>
  rgb 1
sphere_sweep {
  cubic_spline
  n+3,
  #local i=0;
  pigment { rgb y }
  finish { phong 1 }
  rotate <-90,0,0>
background {rgb 1}
#local i=0;
  sphere{<a*sin(i),b*cos(i),0>, r+0.001 pigment {rgb <2,2,0>}}
