POV-Ray : Newsgroups : povray.newusers : Lightcurve inversion Server Time
19 Aug 2025 06:46:55 EDT (-0400)
  Lightcurve inversion (Message 1 to 4 of 4)
Subject: Lightcurve inversion
Date: 10 Jan 2006 16:20:00
Message: <web.43c4245891cc8ba33a6d2d290@news.povray.org>
I am a new user to Pov-ray.
I have experience writing C code but not C++.
my question is this:
I am atempting to create an image from photometric lightcurve data of an
asteroid.
Does anybody know of code available for lightcurve inversion or will i have
to try and write some myself??
Subject: Re: Lightcurve inversion
Date: 10 Jan 2006 17:04:16
Message: <43c42f60$1@news.povray.org>
"Dan_The_Man" <dan### [at] hotmailcom> wrote in message
news:web.43c4245891cc8ba33a6d2d290@news.povray.org...
> asteroid.
I don't. Could be interesting stuff.
Is it based on rotation and time, then?
Making guesses here, but it might only cover one brightness change during a
one-axis spin, or something like that. Basically similar to a variable star
lightcurve, perhaps, so the shape and brightness would be seen as the same
thing. In fact, if it were more complex data than that, you might have a lot
of work ahead by having to figure other aspects, such as precession, if it
is indeed only a lightcurve varying over multiple spins of the asteroid.
Still, sounds intriguing to try and create a surface texture or shape from
such information.
In the most simplistic way I think it should be easy to just vary color
(brightness) across the face of a sphere. Nothing much to that. If there are
multiple spins then a series of spheres (blob) could be textured separately
along a spline, so that it creates both a surface and brightness as it goes
around a central point. That would probably be what I'd try anyway. Not sure
of meshes or other possibilities but other people could say if they see your
message and reply. A lot depends on the actual way that data is done.
Date: 12 Jan 2006 10:05:01
Message: <web.43c66fc0e7dfbc3a6d2d290@news.povray.org>
thanks for your reply
yes indeed it is very like a variable star lightcurve. although here the
change in brightness is cause almost entirely from the shape of the
asteroid, albedo effects are not as important as the shape.
all i need is an algorithm to convert the change in intensity relative to
the phase (over a single period i mite add) to that of the shape of a
convex hull.
any ideas??
Date: 14 Jan 2006 04:41:02
Message: <43c8c72e$1@news.povray.org>
news:web.43c66fc0e7dfbc3a6d2d290@news.povray.org...
Welcome to it, few and far between as they are.
> convex hull.
> any ideas??
Thinking this over again...
The two ideas I had in mind before are imperfect for what you're asking...
from what I can figure anyway.
The first, a variable brightness change across the face of a sphere,
wouldn't show any shape. I understand you're saying that the asteroid would
instead most likely need to be modeled with size changes based on the
orientation the lightcurve is meant to deduce-- or show faces oriented
toward the observation in a relative size according to brightness.
The second, using an object with size change as it wraps around a central
point, would cause the smaller sides to be overwhelmed by the larger sides
unless the distance they are placed outward from the central point happened
to be farther than the distance the largest sides are in breadth and height.
In other words, overlap could negate the smallest dimensions or the
distended shape could look like a chewed donut if seen from above. Hopefully
I'm describing this in a way that makes sense to you.
Although I'm fresh out of really good ideas at the moment at least I have
one other suggestion. You might get some more responses by asking at the
povray.general group since here at povray.newusers the questions and answers
are usually about basic things concerning POV-Ray itself (not sure how many
people visit here). Sorry that this didn't occur to me before now, might
have delayed potential solutions.
I' probably overlooking a simple answer anyway. Also, something I hadn't
mention before is about the method to get the data into POV. You should be
able to set up a #read from a file containing the lightcurve values so that
it is used by an object (or texture, or...?) to create the asteroid model.
But since my ideas are probably flawed I didn't bother to show an example
here. Anyhow, you could be checking into file #open or #read found in the
Help so you can get a grasp of the subject if you don't already know of
that.
