POV-Ray : Newsgroups : povray.newusers : How to increase pixel number in the same size image? Server Time
21 Dec 2025 09:03:55 EST (-0500)
  How to increase pixel number in the same size image? (Message 1 to 5 of 5)
Subject: How to increase pixel number in the same size image?
Date: 29 Nov 2005 10:00:00
Message: <web.438c6c41f6f9beacb7afe1280@news.povray.org>
Hi!
Thank you for your help.
I read your answers for my question. Now, I realize that moe pixels lead to
high resolution at the same size image. Now, our images from POV-RAY are 72
pixels/inch. Can I increase 300 pixels/inch at the same size images? If
not, could you give me idea to increase resolution? I want to generete
publication quality images with POV-RAY.
In addition, after running the program, images are automatically saved to
'bmp FILE'. Can I save it as a compressed file (i.e. jpg) within POV-RAY
program?
Thank you again
Subject: Re: How to increase pixel number in the same size image?
Date: 29 Nov 2005 10:11:09
Message: <438c6f8d@news.povray.org>
> pixels/inch.
  That's in no way POV-Ray's fault. It's just the program you are using
(photoshop perhaps?) which by default prints things at 72 dpi. Just tell
that program to print at a higher dpi.
  Well, if you want to keep the same physical size (in inches) when
printing, you need to render the image at a higher pixel resolution,
obviously.
  I assume you are using the Windows version of POV-Ray. In the upper
left corner there's a drop-down menu with some preset resolutions.
Since those are probably not high enough, you can set your own resolution
in the text-field at the right of that drop-down menu. For example, if
you wanted to render at a resolution of 4000x3000, write this to that
textfield:
-w4000 -h3000 +a
(The "+a" turns basic antialiasing on, which I assume you want.)
> program?
  JPEG is not supported as an output format (only as input) for a pretty
obvious reason: It wouldn't be nice to have a 4-day render only to see
then that your JPEG settings were too low and the image looks like crap.
  A good lossless alternative to bmp is using png, which you can set
by adding "+fn" to the end of that textfield, like this:
-w4000 -h3000 +a +fn
  You can also add "+fn" to the end of the main povray.ini file so that
all images are always saved in the png format and you don't have to
specify it every time (in the tools menu there's an entry to edit povray.ini).
Date: 29 Nov 2005 10:18:45
Message: <dmhrck$psl$1@chho.imagico.de>
James wrote:
> Hi!
Have you read the thread you were pointed to?  From what you wrote it
seems you have not.
Yes, just use '+fn'.
> program?
No.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 29 Nov 2005 14:50:00
Message: <web.438cb0c8ff7a8a80b7afe1280@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> James wrote:
> > Hi!
> seems you have not.
> > program?
> No.
> Christoph
Thank you very much
Date: 29 Nov 2005 23:49:48
Message: <438d2f6c$1@news.povray.org>
>>pixels/inch.
Besides that, the dpi (or ppi, same thing) that's stored in an image
file is nothing more than a data value stored in the file header.  It
has NO effect on the image data itself.  What's more, this value can be
changed arbitrarily by most graphic editing software -- sometimes it can
be obscure to find, but it's generally there someplace.  In Paint Shop
Pro for example, it's in the resize dialog box.  But in reality this
stored dpi value IS TOTALLY IRRELEVANT -- forget about it.  The key
point (as everyone has been telling you) is the image size in pixel
dimensions.
If you are aiming at a specific size/quality, start from there and work
backwards, the math is straight-forward.  For an arbitrary example, say
you want a 20" x 30" poster.  If it's to be printed at 100 dpi it has to
be 2000 x 3000 pixels.  300 dpi would be 6000 x 9000 pixels.  600 dpi
would be 12000 x 18000.  And so on...  (Be prepared for loooooong
renders -- quality takes time.)
Now, the 72 dpi value you see all the time is used simply as an average
video screen resolution.  Naturally, the real ppi value varies with the
screen size and resolution, but 72 is used as a typical average.  That's
why most graphics software uses this as a default dpi value.  But again,
it has no real significance.  When an image is displayed on a video
screen, the stored dpi value is completely ignored -- after all, the
screen has a fixed resolution and can't use anything else.  OTOH,
printers can, and the printing software can adjust the output for
different dpi resolutions.  It might start with the stored dpi value,
but it can adjust it from there, so it's still basically irrelevant.
      -=- Larry -=-
