POV-Ray : Newsgroups : povray.newusers : Spotlight and media produce circular artefacts - Help ? Server Time
20 Mar 2026 14:08:35 EDT (-0400)
  Spotlight and media produce circular artefacts - Help ? (Message 1 to 7 of 7)
Subject: Spotlight and media produce circular artefacts - Help ?
Date: 20 Jun 2005 06:55:01
Message: <web.42b69f52a6ab8cf34f17dd8d0@news.povray.org>
Hi all, especially Houston!
I've got a problem.
I want to set up an underwater station with spotlights pointing in +/- all
directions. The scene I made produced some strange artefacts (not shown
here).
So I set up a test scene containing 11 spots, media and cam only. I could
see black circles produced at the end of the spots pointing towards -z.
What can I do to get rid of these?
The athmospheric media (medium...) is Rayleigh or Henyey-Greenstein
scattering. System is Windows XP.
The scene (below) should render in ~20 s at medium image size.
Hope you could give me some hints!
Yours,
Bu.
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.6
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: Burki
// #version 3.6;
global_settings {
  assumed_gamma 1.0
  max_trace_level 15  //         <--- Max Trace quite high
  ambient_light 0
// ---------------------- CAM ------------------
  location  <0.0, 4.5, -12.0>
  direction 1.2*z
  look_at   <0.0, 0.0,  0.0>
// -------- Athmospheric Media ---------
media {
  scattering {
     4,                      // 4=Rayleigh; 5=Henyey-Greenstein
     rgb <0.4, 1, 0> * 0.02  // color / 'density'
  method 3               // adaptive sampling
#declare spot =
light_source {
  0
  color rgb 100                 //  LIGHT COLOR 100 !!!
  spotlight
  translate <1, 0.0, 0>         // 1 unit right
  point_at  <2, 0.1, 0>         // slightly upward
  radius 5
  tightness 50
  falloff 8
  fade_distance 1               // fades fast
  fade_power 2
// number_of_spots Spots in a circle (e.g. eleven)
#declare spot_count = 0;
#declare number_of_spots = 11;
#while (spot_count < number_of_spots)
        object {
                spot
                rotate spot_count * 360/number_of_spots *y
#declare spot_count = spot_count + 1;
// no objects, just light, media and cam.
///////////////////////////////////// END
Subject: Re: Spotlight and media produce circular artefacts - Help ?
Date: 20 Jun 2005 12:25:00
Message: <web.42b6ed9565fa2156a3607400@news.povray.org>
"Burki" <nomail@nomail> wrote:
> spotlights pointing in +/- all directions. The scene I made produced some
> strange artefacts
Hi Burki!
You're trying to cast spotlights towards infinity... and, quoting
3.3.2.1  Atmospheric Media :
"Note: POV-Ray cannot sample media along an infinitely long ray. The ray
must be finite in order to be possible to sample. This means that sampling
media is only possible for rays that hit an object. "
The black circles are not in the z-negative direction but rather in the
z-positive. They show up when Pov stops sampling after some length of the
cone of light. Add a plane {z, 2000 inverse pigment {rgb .5}} to your
scene, you'll discover that pov stops sampling around +2000 in the z
direction. Hence a possible workaround: arrange your scene so that theres
something for the spotlight to hit before +2000*z, or tweak the camera so
that these artifacts are out of view.
Hoping this helps!
JYR
Windows XP HomeEdition//AMD Athlon XP 2800+1 MB RAM
Date: 20 Jun 2005 13:15:01
Message: <web.42b6f86765fa2156a3607400@news.povray.org>
On second thought... You have a short fade distance, thus a short visible
light cone . Try adding a transparent plane not too far in the z-positive
direction :
plane {z, 200 inverse pigment {rgbt 1}}
just to limit the sampling distance. Then, of course, i don't know what your
whole scene should look like, maybe this is not an option...
JYR
Windows XP HomeEdition//AMD Athlon XP 2800+//1 MB RAM
Date: 20 Jun 2005 20:07:19
Message: <42b75a37$1@news.povray.org>
Burki nous apporta ses lumieres en ce 2005-06-20 06:52:
> I've got a problem.
> here).
> Yours,
> Bu.
> // File: ?.pov
> // Vers: 3.6
> // Date: mm/dd/yy
> // Auth: Burki
> // #version 3.6;
> global_settings {
>   assumed_gamma 1.0
>   ambient_light 0
> camera {
>   direction 1.2*z
> media {
>   scattering {
> #declare spot =
> light_source {
>   0
>   spotlight
>   radius 5
>   tightness 50
>   falloff 8
>   fade_power 2
>         object {
>                 spot
> #end
There are to few samples for your situation,
Put your media in a large hollow box as follow:
box{50,-50 pigment{rgbt 1}
	interior{
		media {
		  scattering {
		     rgb <0.4, 1, 0.0> * 0.02  // color / 'density'
		  method 3   // adaptive sampling. default, don't need to specify
		  samples 15 // increase as needed, weak effect on render time
	hollow
This will limit the rays to a finite distance. I increased the number of samples, it
was also a
cause of your artefacts.
Date: 21 Jun 2005 17:10:01
Message: <web.42b8814665fa2154f17dd8d0@news.povray.org>
I'd simply forgotton this not so unimportant fact ...
Alain <ele### [at] netscapenet> wrote:
> There are to few samples for your situation.
Yes ! Now it begins to work. I also increased the intervals in the test
scene. In the original scene the beams looked a bit like a string of beads.
Increasing the intervals from 10 to 30 helped to produce a more constant
beam. But this also demands a greater rendering time.
Originally I wanted that a spot should shine out of every window. As I made
7x49 windows in total I think I'm going to drop this idea ...
You helped me a lot, especially in encouraging me to read more in the help
files   :)
Thanks,
Bu.
Date: 21 Jun 2005 20:14:37
Message: <42b8ad6d$1@news.povray.org>
Burki nous apporta ses lumieres en ce 2005-06-21 17:06:
Have a parallel light_source some distence away. Using a single light can help reduce
your render
time. Be sure that it's far enough so that anything suposed to cast a shadow is closer
than the
location of your light.
> files   :)
> Thanks,
> Bu.
Using method 3, it's beter to increase samples than intervels. Less chance to get
artefacts and
normaly faster.
My tests using your sample scene: (render times)
intervals 25 in 14' 31"
samples 25 in 2' 46" still some artefacts
samples 50 in 5' 04" no notable artefact, smooth, at least as good as 25 intervals
samples 75 in 6' 59" very, very smooth, probably overkill
samples 100 in 8' 57" no notable improvement, overkill
Date: 22 Jun 2005 15:05:02
Message: <web.42b9b5eb65fa215d61e8c370@news.povray.org>
> artefacts and normaly faster.
Thanks, Alain!
I repeated your experiments and came to the same results. Not exact the same
time of course. I put everything in a 'sphere {0,50 hollow}'.
This was really very helpful.
Yours,
Bu.
