![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On:
cylinder {
<-1.835, 1.012, -0.3288>, <-1.835, 1.012, -0.3288>, 0.02201
I Get:
Parse Error: Degenerate cylinder, base point = apex point.
Can I tell povray to ignore such an invalid cylinder def?
Cheers,
Jurgen
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Can povray ignore errors in scene definitions?
Date: 3 Jun 2005 17:19:02
Message: <42a0c946$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
jfd wrote:
> On:
> cylinder {
> I Get:
> Cheers,
> Jurgen
Are you trying to make a disk (i.e. 2D cylinder)? If so there is a disk
object, I believe it is in "shapes.inc" (search the help file for
"disk"). Otherwise, why not draw the disk as being a very, very thin
cylinder:
cylinder {
<-1.835, 1.012, -0.3287>, <-1.835, 1.012, -0.3288>, 0.0220 }
Bryan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't think so. If you're generating the cylinder automatically, you'll
probably have to use an #if to avoid creating it in the degenerate case. =(
- Slime
[ http://www.slimeland.com/ ]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <42a0ccc8$1@news.povray.org>, "Slime" <fak### [at] email address>
>> - Slime
i agree slime but, if cylinder like this is generated automatically, i
think there are some problems into the "generator" :)))
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
kurtz le pirate nous apporta ses lumieres en ce 2005-06-04 06:17:
>>>- Slime
In that case, POV Ray should issue a warning and continue, not stop with an error. If
you have a
degenerate triangle, you get a warning and the parsing proceed. If you get a
degenerate bounding
box, you get a warning and parsing proceed. That last one hapened to me while making a
macro.
The behaviour I expect: there is a degenerate <anything>, issue a warning, completely
ignore that
element, proceed with the rest of the scene.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
completely ignore that
> Alain
Thanks for your reactions guys. I agree with Alain that povray could simply
proceed after a warning. I can't change the generator (molmol).
Thanks,
Jurgen
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> completely ignore that element, proceed with the rest of the scene.
hmm, could we go as far as saying that there is a consistency issue? A
degenerate cylinder gives a parse error. I could imagine at least one good
reason for that: POV-Ray prevents the caps of the cylinder from being
co-incident surfaces. Now, a degenerate box (with one and only one
dimension set to 0) raises no error, no warning, and is rendered as a
rectangle with no thickness... Am i missing something?
JYR
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
