POV-Ray : Newsgroups : povray.newusers : How to create a beam inside a glass? Server Time
12 Sep 2025 23:12:56 EDT (-0400)
  How to create a beam inside a glass? (Message 11 to 13 of 13)
Subject: Re: How to create a beam inside a glass?
Date: 22 May 2005 11:35:06
Message: <4290a6aa$1@news.povray.org>
You'll need to watch out for coincident surfaces. Those parts which align
perfectly to previous parts, such as what happens in the A and B objects
when together without scaling them to be slightly different. Take note of
the scale 0.999 I added to B.
Here it is again with some changes. I'm not all that good with photons
myself, so this could probably be done better by others, but at least it
shows refraction and reflection of the beam in the glass now. I added
reflection to the finish of the objects, otherwise you would never see that.
global_settings {
//  assumed_gamma 1.9
  max_trace_level 10
  photons {
    adc_bailout       0.01
    spacing           0.1
    gather            20, 100
    media             1, 1
    jitter            0.4
    max_trace_level   5
    autostop          0.5
    radius            0.0
    expand_thresholds 0.2, 35.0
//Camera
         location <0,0,67>
         angle 120
         up 1*y
         right 1.333*x
         look_at <0,0,66>
         translate <-27.5,0,0>
background { color rgb <0.1, 0.5, 1> }
//Scattering
#declare Scattering =
   material
      texture
         pigment
            color rgbt <0.531233, 0.531233, 0.531233, 1>
      interior
         media
            variance 1.0/128.205128
            scattering
               1 ,  rgb <0.03, 0.03, 0.03> // isotropic scattering
               extinction 0.25
#declare Scattering_1 =
   material
      texture
         pigment
            color rgbt <0.0, 0.0, 0.0, 1.0>
      finish {
       reflection {0.1,0.9 fresnel}
      interior
         ior 1.55
         media
            variance 1.0/128
            scattering
               1 ,  rgb <0.5, 0.5, 0.5> // less scatter now
               extinction 0.5 // more extinction here
#declare Scattering_2 =
   material
      texture
         pigment
      finish {
      interior
         ior 1.438
         media
            variance 1.0/128
            scattering
//Checker
#declare Checkered_1 =
   material  // Checkered_1
      texture
         pigment
            checker
               color rgb <0.882353, 0.882353, 0.882353>
               color rgb <0.952941, 0.952941, 0.952941>
         finish
            ambient 0.1
         scale  6.0
//Lights
light_source {   // Light001
  <0.0, 0.0, 0.0>
  color rgb <1.000, 1.000, 1.000>
  media_interaction off
  photons {
   reflection off
   refraction off
  translate  <2, 2, 0>
light_source {<0, 0, 90>
    color rgbt <10,0,0>
    spotlight
    falloff 0.268  // outer radius (in deg)
    radius     0.238
    tightness  0.000
    point_at <0,.5,68>
    photons {refraction on reflection on}
    media_attenuation on
    translate <-27.5,-0.25,0>
box{<-5,-5,-80>, < 5, 5, 80>
    material {
    Scattering
  hollow
    translate -27.5*x
    photons {
     target 1
     reflection on
     refraction on
     collect on
//Plane
plane { // Plane001
  y,-2
  material {
    Checkered_1
  photons {
    target 1
    collect off
//Object
#declare A = merge {object{cylinder {55*z,65*z,0.4}}
                    object{box {<-0.4,-0.25,55>,<0.4,0.25,65>}
                           translate 0.25*y  }}
#declare B = difference{box {<-0.5,-0.5,55>,<0.5,0.5,65>}
                        object {A scale 0.999}}
object {A
        material {
    Scattering_1
  hollow
  photons {
   target 1
    reflection on
    refraction on
    collect on
object { B
         material {
    Scattering_2
  hollow
  photons {
   target 1
    reflection on
    refraction on
    collect on
Date: 22 May 2005 17:04:05
Message: <0us191lvgtkjhba4fg8b363h4imd6m86ih@4ax.com>
On Sat, 21 May 2005 22:53:12 -0500, "Bob Hughes"
<bob### [at] charternet> wrote:
>Well, Stephen, probably good enough, though, eh? One might say, 'Practice
>makes perfect, but never in POV'.
Gosh thanks, and thanks for stepping in. It was 1:30 am my time and as
no one else seemed to be online I thought I would try to pay back some
of the great help I've had.
>I tried your example, changed the scattering and extinction so the beams of
>light show up in a much better way.
Thanks this will go straight into my library.
>Don't know why Moray won't keep those decimals trimmed. Guess that's to make
>it read less human. Ha ha.
My fault, laziness I suppose ,as I used the sliders instead of typing
in values.
>I needed to fix a few lines that word wrapped, so hopefully Ziyan has gotten
>around that, if it happened. And just as a side note, I'm using the new beta
>of 3.7 and it doesn't like hf_gray_16 being in there, nor the
>max_intersections. No idea why, ATM, just pointing this out.
I'm still using 3.5 with Moray.
I should have made it clearer that the media container was to be as
big as the volume, the light was to be visible in. If that makes sense
Regards
Date: 22 May 2005 21:39:36
Message: <42913458$1@news.povray.org>
"Stephen McAvoy" <mca### [at] aolcom> wrote in message
news:0us191lvgtkjhba4fg8b363h4imd6m86ih@4ax.com...
I'm always replying to posts after either just waking up or while
bleary-eyed and half asleep so I know what you mean. For me, that could be
almost anytime!
Does Stephen. I was awfully confused by what Ziyan really wanted to be doing
in the first place. I'm still not exactly sure, just have a clearer idea now
than I did to begin with. Can be sooo difficult to convey ideas in words
sometimes... especially when thinking of things in too complicated a way or
as too simplistic. I had a feeling Ziyan had both in mind so I got
perplexed!
