|  |  | Hello everybody!
I use CSG to build a wall of bricks. It is a union of a box with a mortar
texture and some stones. Each of these sub-objects has is own texture but
now I want to have some kind of paiting on it. The following doesn't work:
object {
 union {
  box {
   <wall_left+0.0001, wall_bottom+0.0001, -0.24>
   <wall_right-0.0001, wall_top-0.0001, 0.24>
    Mortar_Tex
  //stone loop, each stone has is own texture
 texture {                //stupid texture, I know... 8-/
   gradient y
   color_map {
    [0.0 color White filter 1]
    [1.0 color Blue]
   scale 5
So why doesn't it work? Is there a simple way to do that?
|  |  | blenderhead nous apporta ses lumieres en ce 2005-04-02 13:17:
> Hello everybody!
> object {
>  union {
>   box {
>    texture {
>     Mortar_Tex
>   pigment {
>    gradient y
>    color_map {
>     [1.0 color Blue]
>    scale 5
In an union, when you define a texture for any element, that texture have priority and
override any
texture applied to the whole union. The general texture will apply to any element that
DON'T have a
specific texture.
The solution: remove the individual textures.
|  |  | "blenderhead" <nomail@nomail> wrote in message
news:web.424ee1aeef5fde29dfc8659d0@news.povray.org...
> Hello everybody!
Basically, you can't do that (and it's a great shame). What you need to do
is have your outer texture included as a layered texture within each inner
texture.
See 2.3.4.10  Working With Layered Textures in the manual (but iirc the info
on the final normal is incorrect).
and override any
that DON'T have a
> specific texture.
Ok, thank you for explaining this! Though this is somehow disappointing for
me... :,-(
That is not really a solution for me since I want some kind of graffiti on
it when I have finished it. Post a reply to this message
|  |  | Wasn't it blenderhead who wrote:
>Hello everybody!
What you have to do is to layer the graffiti onto both the brick texture
and the mortar texture separately, rather than trying to do both in one
operation. Like this:
#version 3.6;
global_settings {assumed_gamma 1.0}
camera {location  <10,1,-10> look_at <0,.5,0> angle 8}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#declare wall_left = -1;
#declare wall_right = 1;
#declare wall_bottom = 0;
#declare wall_top = 1;
#declare brick_x = 0.2;
#declare brick_y = 0.1;
#declare brick_gap = 0.02;
// The basic textures for mortar, brick and graffiti
#declare Mortar_Tex = texture {pigment {LightGray}}
#declare Brick_Tex  = texture {pigment {Firebrick}}
#declare Graffiti_Tex =
   spherical
   color_map {
    [0.5 color White filter 1]
    [0.6 color Blue]
  translate y*0.5
// Now apply the graffiti to both brick and mortar
#declare Full_Mortar_Tex =
  texture {Mortar_Tex}
  texture {Graffiti_Tex}
#declare Full_Brick_Tex =
  texture {Brick_Tex}
object {
 union {
  // mortar
  box {
   texture {Full_Mortar_Tex}
  // bricks
  union {
   #declare X=wall_left;
   #while (X<wall_right-brick_x)
    #declare Y=wall_bottom;
    #while (Y<wall_top-brick_y)
     box {<X,Y,-0.25><X+brick_x,Y+brick_y,0.25>}
     #declare Y=Y+brick_y+brick_gap;
    #declare X=X+brick_x+brick_gap;
   texture {Full_Brick_Tex}
|  |  | Thank you, it works!
It seems like I have to read the chapter about textures again... ;-)
