POV-Ray : Newsgroups : povray.newusers : uv mapping on a bicubic patch question Server Time
13 Oct 2025 21:10:29 EDT (-0400)
  uv mapping on a bicubic patch question (Message 1 to 4 of 4)
Subject: uv mapping on a bicubic patch question
Date: 26 Feb 2005 00:40:00
Message: <web.42200b7e535873a49101c43e0@news.povray.org>
So I have a bicubic patch and I'm trying to apply two marble pattern
textures to it with uv mapping, one rotated 90 degrees from the other.
Unfortunately the rotation causes the pattern to become stretched instead
of being rotated.  Anyone know why and/or how to fix this?
Subject: Re: uv mapping on a bicubic patch question
Date: 26 Feb 2005 02:54:53
Message: <Ac3IbAA9sCICFwSS@econym.demon.co.uk>
You have to rotate around the z axis only.
(I suppose, theoretically, as a UV mapped texture you ought to rotate
around the W axis, but there isn't one.)
I used
  uv_mapping
  texture {pigment {marble
    scale 0.1
    colour_map {[0.5 rgb 1][0.5 rgb x]}
    rotate z*90
    scale 0.1
    colour_map {[0.5 rgbt 1][0.5 rgb x]}
Mike Williams
Gentleman of Leisure
Date: 26 Feb 2005 04:20:00
Message: <web.42203e2d4c61b44e4c2afc5a0@news.povray.org>
> I used
>   uv_mapping
>     scale 0.1
>     rotate z*90
>     scale 0.1
> Mike Williams
Thanks, that was exactly what I was looking for.
Subject: isosurfaces problem (hello Mike)
Date: 26 Feb 2005 05:54:56
Message: <kurtzlepirate-CD0CD2.11545626022005@news.povray.org>
hello,
i want to model cable with 2 parts : cylindrical and part of torus.
for cylindrical, i have no problem. code i use is :
#declare p1 = 8;    // number of helixes
#declare p2 = 0.25; // number of turns per unit length
#declare p3 = 1.75; // minor radius
#declare p4 = 1.50; // major radius
#declare p5 = 1.00; // shape parameter
#declare p6 = 1;    // cross section type -> circle
#declare p7 = 0;    // cross section rotation angle
#declare containerSize = 3.20;
#declare maxGradiantValue = 10;
#declare cableFunction = function { f_helix1(x, y, z, p1, p2, p3, p4,
p5, p6, p7) }
#declare cableCyl = isosurface {
  function { cableFunction(x,y,z) }
  contained_by {
    box { <+containerSize, 0.00, +containerSize> <-containerSize,
-cableLen, -containerSize>   }
  max_gradient maxGradiantValue
for "torus part", i do this code :
#declare cableTorus = isosurface {
  function { cableFunction(f_r(x,y,z)-MajorRadius, y, f_th(x,y,z)) }
  contained_by {
    sphere { 0,*MajorRadius1.2 }
  rotate 90*x
with MajorRadius = 80.00
... but all the thing a get is a plain torus !!!
anyone can help me ?
thanks
