![](/i/fill.gif) |
Wasn't it Mienai who wrote:
>So I have a bicubic patch and I'm trying to apply two marble pattern
>textures to it with uv mapping, one rotated 90 degrees from the other.
>Unfortunately the rotation causes the pattern to become stretched instead
>of being rotated. Anyone know why and/or how to fix this?
You have to rotate around the z axis only.
(I suppose, theoretically, as a UV mapped texture you ought to rotate
around the W axis, but there isn't one.)
I used
uv_mapping
texture {pigment {marble
scale 0.1
colour_map {[0.5 rgb 1][0.5 rgb x]}
rotate z*90
scale 0.1
colour_map {[0.5 rgbt 1][0.5 rgb x]}
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
![](/i/fill.gif) |
> I used
> uv_mapping
> scale 0.1
> rotate z*90
> scale 0.1
> Mike Williams
Thanks, that was exactly what I was looking for.
![](/i/fill.gif) |
![](/i/fill.gif) |
hello,
i want to model cable with 2 parts : cylindrical and part of torus.
for cylindrical, i have no problem. code i use is :
#declare p1 = 8; // number of helixes
#declare p2 = 0.25; // number of turns per unit length
#declare p3 = 1.75; // minor radius
#declare p4 = 1.50; // major radius
#declare p5 = 1.00; // shape parameter
#declare p6 = 1; // cross section type -> circle
#declare p7 = 0; // cross section rotation angle
#declare containerSize = 3.20;
#declare maxGradiantValue = 10;
#declare cableFunction = function { f_helix1(x, y, z, p1, p2, p3, p4,
p5, p6, p7) }
#declare cableCyl = isosurface {
function { cableFunction(x,y,z) }
contained_by {
box { <+containerSize, 0.00, +containerSize> <-containerSize,
-cableLen, -containerSize> }
max_gradient maxGradiantValue
for "torus part", i do this code :
#declare cableTorus = isosurface {
function { cableFunction(f_r(x,y,z)-MajorRadius, y, f_th(x,y,z)) }
contained_by {
sphere { 0,*MajorRadius1.2 }
rotate 90*x
with MajorRadius = 80.00
... but all the thing a get is a plain torus !!!
anyone can help me ?
thanks
![](/i/fill.gif) |
