POV-Ray : Newsgroups : povray.newusers : auto scaling an object to fit x% of image Server Time
20 Mar 2026 17:34:10 EDT (-0400)
  auto scaling an object to fit x% of image (Message 1 to 3 of 3)
Subject: auto scaling an object to fit x% of image
Date: 11 Feb 2005 00:05:01
Message: <web.420c3c53b7391ab94342870a0@news.povray.org>
Hi
I have figured out a little macro to autocenter an object (see below), but I
would like to auto scale that object to fill x% of the image x and y
dimensions.
I know of image_height and _width and I suspect that the calculation I need
has something to do with the camera angle and other camera params, but I am
not sure how to proceed. Also, I would like this to work for a perspective
camera and an orthographic camera.
I would appreciate some help, thanks
#macro AUTOCENTER(SomeObject)
 This macro redeclares the input object so as to do the autocentering
 on that object .. see help 3.2.2.8.5  Returning Values Via Parameters
 This means that a usage like AUTOCENTER(sphere{whatever} is not legal
 - you have to pass in an object.
 min_extent is not guaranteed to work with all csg objects.
#local jaMin = min_extent ( SomeObject );  // corner 1
#local jaMax = max_extent ( SomeObject );  // corner 2
#local jax =(jaMin.x+jaMax.x)/2;
#local jay =(jaMin.y+jaMax.y)/2;
#local jaz =(jaMin.z+jaMax.z)/2;
#declare SomeObject = object{SomeObject translate <-jax,-jay,-jaz> }
#end // end of macro
Subject: Re: auto scaling an object to fit x% of image
Date: 18 Feb 2005 07:48:25
Message: <Xns96018C73F9665jgrimbertmeandmyself@203.29.75.35>
> Hi
> but I would like to auto scale that object to fill x% of the image x
> and y dimensions.
> need has something to do with the camera angle and other camera
> params, but I am not sure how to proceed. Also, I would like this to
> work for a perspective camera and an orthographic camera.
Orthographic camera: the image scope is given by the right and up
vector's length.
 up 1*y
 right 1*x
give a 1x1 scene size, stretched over image_height and _width.
Perspective camera: have faith in the maths, for not so narrow angle, you
have a distortion near the border: a circle is not a circle anymore!
Best hint from me: Use the source for the camera ray computation and
reverse the math for some fixed %, assuming a central position of the
object. Or do it the caltech way...
This is an unauthorised cybernetic announcement.
When someone says "I want a programming language in which I need only
say what I wish done," give him a lollipop.
Date: 18 Feb 2005 17:45:01
Message: <web.42166f2dc8f2865198e4127b0@news.povray.org>
ok, maybe I can reverse the math. But what is the "caltech way"?
