POV-Ray : Newsgroups : povray.newusers : Silent rendering Server Time
20 Mar 2026 19:15:32 EDT (-0400)
  Silent rendering (Message 1 to 5 of 5)
Subject: Silent rendering
Date: 16 Jan 2005 00:40:00
Message: <web.41e9fdccbdaf629ee466bc440@news.povray.org>
Im trying to use PovRay from my own program to render some (simple) images.
So far I have been able to start Povray from the command line to do so, but
on every run the povray window comes up, renders the image and then closes
again. I use the command line options '/RENDER' and '/EXIT'. Is there any
way to render images with povray without a window popping up? Is there
probably even an easy way to access the povray functionality directly
without having to start the program itsself?
Im working with the windows version.
Thx for any hints.
Robert
Subject: Re: Silent rendering
Date: 16 Jan 2005 05:47:07
Message: <41ea462b@news.povray.org>
> Is there any
If the only window popping up is the display window (that is, not the
editor, which I think should be the case if you're running the right
executable), then try adding -D to the command line arguments.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 16 Jan 2005 08:05:01
Message: <web.41ea65845bf4cb22e466bc440@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote:
> > Is there any
>  - Slime
Well it is the editor. Your answer tells me there should be more than one
executable. I searched the Povray installation folder and only found one
executable. And that one is starting the editor.
Where can I get other executables? Or am I just stupid?
Date: 16 Jan 2005 13:38:17
Message: <41eab499$1@news.povray.org>
For some reason I was under the impression that the editor and renderer were
separate executables, but apparently I was wrong.
 - Slime
Date: 17 Jan 2005 03:19:09
Message: <41eb74fd@news.povray.org>
Hi Robert!
AFAIK you got two options:
- use QuietPOV (http://www.dreampeach.com/QuietPOV/)
- use PovCyg, a POV-Ray port to the CygWin Unix emulator which runs
   under Windows.
   PovCyg: http://www-public.tu-bs.de:8080/~y0013390/povcyg/index.html
   CygWin: http://www.cygwin.com/
Both should do what you need.
HTH,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
