POV-Ray : Newsgroups : povray.newusers : Cannot layer over a patterned texture : hum ???? Server Time
21 Dec 2025 22:37:31 EST (-0500)
  Cannot layer over a patterned texture : hum ???? (Message 1 to 3 of 3)
Subject: Cannot layer over a patterned texture : hum ????
Date: 21 Dec 2004 06:00:01
Message: <web.41c800ef18a96d1fe5987fa60@news.povray.org>
Hi have a scene w/ the following object :
#declare terrain = height_field {
 png "Eau.png"
 smooth
  material_map {
   png "Eau_m.png"
     slope y
     color_map {
      [0 White]
      [0.60 SteelBlue*0.1]
      [0.65 White*2]
      [0.7 Gray95]
      [0.75 Gray80]
      [0.85 MediumForestGreen]
      [1 ForestGreen]
   texture {pigment { Jade } scale 1/60 } // Foret
  rotate x*90
 translate <-.5, 0, -.5>
 scale <6900,65535,6075>
 finish { ambient rgb <0.1,0.2,0.1> }
But when I'm trying to generate the scene, I got following message :
File: Eau.pov  Line: 35
File Context (5 lines):
                rotate x*90
        finish
Parse Error: Cannot layer over a patterned texture.
Can someone explain me why I got this kind of error ? I don't understand has
I use the same script (I think ;-D) w/ another scenes and it's working
perfectly.
Thanks
Lolo
Subject: Re: Cannot layer over a patterned texture : hum ????
Date: 21 Dec 2004 06:15:01
Message: <cq90b4$9jg$1@chho.imagico.de>
> perfectly.
I doubt that - see what's different in the other scenes and you will
realize what's wrong.
You are trying to layer a second texture (the "finish { ambient rgb
<0.1,0.2,0.1> }") over the material_map texture and this can't work.
What you probably want to do is place that finish where it belongs -
namely inside the textures of the material map.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 21 Dec 2004 08:10:00
Message: <web.41c81f74efdb3a57e5987fa60@news.povray.org>
Hi Christoph,
Yes, you're right : I forgot to remove this line after my copy/past.
Thanks a lot, it's working now :-)
Laurent
