POV-Ray : Newsgroups : povray.newusers : Isosurface object calling an external function/program??? Server Time
10 Apr 2026 14:23:36 EDT (-0400)
  Isosurface object calling an external function/program??? (Message 1 to 3 of 3)
Subject: Isosurface object calling an external function/program???
Date: 2 Nov 2004 10:25:01
Message: <web.4187a58d139a9eb41ad39b350@news.povray.org>
I would like to use POV-Ray for scientific visualisation. The isosurface
capability sounds very interesting for my problem. In my case however, the
function I need to evaluate is a bit complicated (and involves sums of
elements defined outside POV-Ray). Is it possible to call a function
defined outside POV-Ray (in a shared lib) inside the isosurface object???
Could anyone give me an exemple of how to do this?
Thanks,
Subject: Re: Isosurface object calling an external function/program???
Date: 2 Nov 2004 10:51:19
Message: <4187acf7$1@news.povray.org>
> Hi,
> Thanks,
Not without patching POVRay... Unless the output of said library is
"fixed" then you could technically write the data out to a flat file,
and load it into POVRay with the file IO directives.
~Mike
Date: 2 Nov 2004 11:10:02
Message: <cm8b9n$72t$1@chho.imagico.de>
> Hi,
e
the
You would need to modify POV-Ray for this and it would break portability
of the program.  If the function is too complicated to be implemented in
SDL it is unlikely that it would be efficient to render an isosurface
directly from it (this uses a *lot* of function evaluations).  Better
use a df3 file generated with a separate program.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
