Yes Mike, Ok, now that's right.
isosurface {
function { f_helix1 (x, y, z, 2, 3, 4, 5, 0.1, 1, 25) }
max_gradient 6
contained_by {sphere {0, 1.2} }
pigment {rgb .9}
Thank you very much,
Oleguer
news:1Dqe$HAo1EfBFwh0@econym.demon.co.uk...
> Wasn't it Oleguer Vilella who wrote:
> >Why it doesn't work?
> >#include "functions.inc"
> >#include "colors.inc"
> >camera {
> > location <7, 25, -20>
> > look_at <5, 3.0, 0.0> }
> >light_source { <-100,200,-100> colour rgb 1 }
> >background { White }
> >isosurface {
> >function { f_helix1 (1, 1, 1, 2, 3, 4, 5, 0.1, 1, 25) }
> > max_gradient 1.5
> > pigment {rgb .9}
> The main reason is that you're only evaluating a single point of the
> function. You should say "f_helix1 (x,y,z..." not "f_helix1 (1,1,1..."
> You'll also need to increase your max_gradient to about 6.
> Mike Williams
> Gentleman of Leisure
How can I rotate it? and how can I translate it? Of I do this it gives me an
error:
isosurface {
function { f_helix1 (x, y, z, 2, 3, 4, 5, 0.1, 1, 25) rotate x*25 }
max_gradient 6
pigment {rgb .9}
Many thanks,
Oleguer
news:417c9e05$1@news.povray.org...
> isosurface {
> max_gradient 6
> pigment {rgb .9}
> Oleguer
> > >camera {
> > >isosurface {
> > > max_gradient 1.5
> > > pigment {rgb .9}
> > Mike Williams
>error:
>isosurface {
> max_gradient 6
> pigment {rgb .9}
Rotate the isosurface, not the function
isosurface {
max_gradient 6
rotate x*25
pigment {rgb .9}
Mike Williams
Yes, Ok Mike, I can't rotate the function, but why?
Thanks,
Oleguer
news:qMf### [at] econym demon co uk...
an
> >error:
> >isosurface {
> > max_gradient 6
> > pigment {rgb .9}
> isosurface {
> max_gradient 6
> rotate x*25
> pigment {rgb .9}
> Mike Williams
It just doesn't happen to be part of the standard syntax, and rotating
the isosurface does what you want, so there's not much point for someone
to take the trouble to add it.
You can achieve function transformations by substituting variables, like
this:
#declare Cos25 = cos(radians(25));
#declare Sin25 = sin(radians(25));
isosurface {
function { f_helix1 (x-1, y*Cos25+z*Sin25, z*Cos25-y*Sin25,
max_gradient 6
contained_by {sphere {x, 1.2}}
pigment {rgb .9}
The "x-1" does exactly the same as a "translate x" (observe that I had
to move the "contained_by" object as well, and the syntax doesn't even
allow you to use "translate x" there either).
The "y*Cos25+z*Sin25, z*Cos25-y*Sin25" bit does the same as "rotate
x*25".
Mike Williams
"Akuma" <afr### [at] hotmail com> wrote:
> I've been trying to create a strand of DNA using an isosurface. However, I
> keep having trouble creating the double helix using the function f_helix1
> found in functions.inc
> Could anybody give me an example double helix for me to start with? It'd be
> a big help.
There's a DNA strand included in the CrystalPOV scene template package. I
took the strand from Accelrys DS. In this program there's also a structure
data file included from a DNA strand. You can use several molecular
structure visualization programs to convert this data into a pov-ray scene
file. If You should not find it, i can send You the pov file.
Shu
> > a big help.
> Shu
I had been thinking about creating a DNA backbone with POVray for quite a
while. With some of the information on here I came up with this that works
very nicely:
location <0, 0, 50>
look_at <0, 0.0, 0.0> }
light_source { <00,0,100> colour rgb 1 }
background { rgb <0,0,0> }
#declare double = union {
isosurface {
function { f_helix1 (x,y,z,1,1,0.5,2,1,1,-180) }
max_gradient 2
contained_by {sphere {1, 20} }
pigment {rgb <1,1,1>}
isosurface {
max_gradient 2
rotate <0,120,0>
object {
double
There is one MAJOR problem. This makes a left-handed helix. DNA should be
right-handed. Does anyone know how to change this?
"Paul P." <nomail@nomail> wrote in message
news:web.43fa7c9689e84e742c710c840@news.povray.org...
>> > However, I
>> > f_helix1
8<---snip---8<
The period (second number after x,y,z) can be negative to turn it the other
direction. Could also use just one f_helix1 by specifying 2 as the first
number to double the strand. And... if 2 is used for the 3rd to last number
(said to be the type) then that will make it square for a ribbon-like
appearance when using a 45 degree rotation as the last parameter, should
look much like many illustrations show it.
Bob H
I just put the following example together, starting with yours, to look like
the one I found at
http://marsprogram.jpl.nasa.gov/express/newsroom/pressreleases/20030501a_image02.html
A little more internet searching doesn't help me fix this up any better so
I'll leave that all up to you.
Beware, this wasn't based on anything real and the rods (or whatever they
are called officially!) are only a hack to fit the ribbons.
#declare DH = union {
isosurface {
function { f_helix1 ( x, y/2, z, 2, -1, 0.25, 2, 2, 2, 45) }
max_gradient 2
#local I=-0.9;
#while (I<=1)
union {
cylinder {-x*2,-x/5,0.25 pigment {rgb <1,1,0>}}
cylinder {x/5,x*2,0.25 pigment {rgb <0,1,0>}}
rotate 90*y rotate -I*1.6*360*y
translate I*20*y
#local I=I+0.05;
object {
DH
> Bob H
Thanks! I thought I tried putting negatives everywhere, but that certainly
works. The only issue with using the 2 in the fhelix1 function for the two
strand is that there doesn't appear to be a way to change phase of the
strands. For biological correctness, DNA has alternating major and minor
grooves (see my first example). It was simple enough to make two identical
backbones and rotate one 120 degrees to set the proper phase.
Thanks for the help.
--paul
news:web.43fb41c589e84e74d937d540@news.povray.org...
>> other
Glad to have helped any at all.
I had a feeling it shouldn't be so symmetrical, especially after seeing all
the variations I could find through internet searching for a picture of one.
I chose the easiest route. Biology wasn't my favorite subject in school,
chemistry was. :)
Bob H
