POV-Ray : Newsgroups : povray.newusers : Background is not rendered Server Time
20 Nov 2025 19:00:52 EST (-0500)
  Background is not rendered (Message 1 to 4 of 4)
Subject: Background is not rendered
Date: 19 Oct 2004 11:35:00
Message: <web.417533573836a2c2ea905ff0@news.povray.org>
I've made many many drawing with Moray & Povray on my own computer.  Now i'm
working on my friend computer and i've got a problem: My background is not
rendered.  It's a simple gray color.  When i render it, in Moray my
background is black, and in Povray my background is full of little square
.... like if no background was drawn.
Any idea of what's wrong?
Thanks for your help
Christian
Subject: Re: Background is not rendered
Date: 19 Oct 2004 13:35:19
Message: <41755057@news.povray.org>
Rage30 wrote:
> Hi,
> Christian
I wonder if you have the output_alpha setting on or off?
I seem to remember having this problem that instead of a
black/grey/white background to my images, produced .TGA files had the
squares you refer to as background. I think this has to do with the
output_alpha ini settting.
You will most likely find that your output_alpha ini setting is "on" -
change it to "off" and see if it will work. Here is an .ini file snippet
   where I have turned mine off:
Output_Alpha=Off
Output_File_Name="0017"
Output_File_Type=t
Output_To_File=On
Palette=9
Stefan Viljoen
Software Support Technician
Polar Design Solutions
Date: 19 Oct 2004 23:24:05
Message: <4175da55$1@news.povray.org>
Rage30 nous apporta ses lumieres ainsi en ce 2004-10-19 11:31... :
>Hi,
>Christian
There is nothing wrong! That's what I get when I render something using
the alpha chanel. The background colour is effectively transparent
leting you see the filler.
Date: 25 Oct 2004 10:05:00
Message: <web.417d075c8cc7817fea905ff0@news.povray.org>
Thanks a lot Stefan,
it was my problem.
i've changed that parameter in the ini file and now it's rendering
perfectly.
Christian
Stefan Viljoen <ryl### [at] intekomcoza> wrote:
> Rage30 wrote:
> > Hi,
> > Christian
> Output_Alpha=Off
> Output_File_Type=t
> Output_To_File=On
> Palette=9
> Regards,
> Stefan Viljoen
