![](/i/fill.gif) |
Dave! <orr### [at] no_spam_please excite com> wrote:
> However, I sort of accidentally discovered that I could create the surface I
> needed more easily through a matrix transformation of a simple cylinder.
Since you can't turn a cylinder into a conical shape where each end has
a different size with a matrix transformation, and since a transformed
cylinder is exactly what you wanted, your original description of the
problem was not very accurate... :P
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
![](/i/fill.gif) |
Well, mis-diagnosis is part of the problem, sure! I'm modelling from a
real-world object, and my initial description was based on my initial
(admittedly incorrect) study of the object. I didn't realize until last
night that the surface I needed was cylindrical rather than conic.
Still, I've received lots of good info about isosurfaces, so it works out
for me either way!
Dave!
![](/i/fill.gif) |
