POV-Ray : Newsgroups : povray.newusers : Volume and Area Calculations in POV-Ray ? Server Time
14 Oct 2025 06:42:54 EDT (-0400)
  Volume and Area Calculations in POV-Ray ? (Message 1 to 4 of 4)
Subject: Volume and Area Calculations in POV-Ray ?
Date: 24 Sep 2004 18:45:00
Message: <web.4154a3219588c952536167b10@news.povray.org>
Can I use POV-Ray also for doing area and volume calculations ?
Here is an example:
Suppose the mathematical function y=exp(-x^2). Greetings to Gauss !
Now this function rotates around the z-Axis.
Now I cut off a cylinder from this volume.
Maybe along the x-Axis.
Is it possible to calculate the volume that was cutted off ?
Good night
Subject: Re: Volume and Area Calculations in POV-Ray ?
Date: 25 Sep 2004 06:53:06
Message: <LywuSCAq3UVBFw1O@econym.demon.co.uk>
>Here is an example:
You can find a numerical approximation to the volume by firing lots of
trace() calls at it and adding up the volumes of the columns. The
smaller the Step size between the trace() positions, the more accurate
will be the calculated volume.
// Create the shape
#declare E = 2.71828;
#declare THING = intersection {
  isosurface {
    function { y-pow(E, -(x*x+z*z)) }
        max_gradient 1.4
        contained_by{box{<-3,0,-3><3,1,3>}}
  cylinder {-x*3,x*3,1}
// This bit is so that you can check that the
// THING is the shape that you expected it to be.
// It's not necessary for the volume calculation
camera { location  <3, 1, -4> look_at <0, 0, 0> angle 50}
light_source {<-100,200,-100> colour rgb 1}
object {THING
  pigment {rgb .9}
  finish {phong 0.5 phong_size 10}
// Set the range over which to iterate
#declare Xmin = min_extent(THING).x;
#declare Xmax = max_extent(THING).x;
#declare Zmin = min_extent(THING).z;
#declare Zmax = max_extent(THING).z;
// Trace the rays
#declare Norm = <0,0,0>;
#declare Total=0;
#declare Step = 0.05; // Set smaller for more accuracy
#declare X=Xmin;
#while (X<Xmax)
  #declare Z=Zmin;
  #while (Z<Zmax)
    #declare P1=trace(THING, <X,100,Z>, -y);
    #declare P2=trace(THING, <X,-100,Z>, y, Norm);
    // Test to see if the trace hit anything
    #if (vlength(Norm)>0)
      #declare Total = Total + P1.y - P2.y;
        #declare Z=Z+Step;
  #declare X=X+Step;
// Calculate the volume
#declare Volume = Total*Step*Step;
#debug concat ("Volume = ", str(Volume,-1,-1), " cubic POV units\n")
Date: 25 Sep 2004 11:35:01
Message: <web.41558ec6ea4355ba86e5b6190@news.povray.org>
First, thank you for your help.
My problem is:
I want to translate the tunnel (the cylinder) along the y-axis.
A translation of the cylinder inside the #declare THING does not work.
the CSG object cylinder or an isosurface.
Thank you in advance
#declare IsoFinish =
finish {
 ambient 0 diffuse 1
 specular 1 roughness 0.02
 brilliance 2
#declare isocylinder =
isosurface
 function {sqrt(x*x + y*y) - 0.5}
 threshold 0
 contained_by {box {<-1,-1,-1>, < 1, 1, 1>}}
 texture
  pigment {color Red}
  finish {IsoFinish}
 translate < 1, 2, 0>
#declare isoepsilon =
isosurface
    max_gradient 1.4
    accuracy 0.02
    contained_by{box{<-2,0,-2><2,1,2>}}
#declare THING = difference
isosurface
    max_gradient 1.4
    accuracy 0.01
isosurface
 function {sqrt(y*y + z*z) - 0.2}
 threshold 0
 texture
  pigment {color Red}
  finish {IsoFinish}
 translate < 0, 0.5, 0>
// Create the shape
  isosurface {
        max_gradient 1.4
  cylinder {-x*2,x*2,0.2}
light_source {<-100,200,-100> colour rgb <0.9, 0.9, 1.0>}
object
{ THING
  pigment {rgb .9}
// Trace the rays
#declare Total=0;
#declare X=Xmin;
#while (X<Xmax)
  #declare Z=Zmin;
  #while (Z<Zmax)
        #declare Z=Z+Step;
  #declare X=X+Step;
#debug concat ("Volume = ", str(Volume,-1,-1), " cubic POV unitsn")
Date: 25 Sep 2004 12:31:10
Message: <z+BPAFAuzZVBFwj3@econym.demon.co.uk>
>My problem is:
The problem that you're seeing with the rendered image is because you
need a higher max_trace (or all_intersections). NB Don't confuse this
with the similarly named max_trace_level, that's something completely
different.
A CSG cylinder will do the job just as well and will render and trace()
faster because POV can solve directly for the point where the ray hits
the surface rather than having to hunt for it with a series of guesses.
My tracing code assumed a convex object, it only looks for the first and
last surface it encounters when looking downwards. The easiest way to
fix this is to calculate the volume of the outside part and the volume
of the hole separately and then subtract one from the other.
finish {
 ambient 0 diffuse 1
 brilliance 2
#declare THING1 = isosurface
    max_gradient 1.4
    accuracy 0.01
    all_intersections
#declare THING2 = intersection {
  object {THING1}
  cylinder {<-3,0,0><3,0,0>,0.2 translate <0, 0.5, 0>}
difference {
  object{ THING1
    pigment {rgb .9}
    texture  {
      pigment {color Red}
      finish {IsoFinish}
// Remember that THING1 is the bigger one
#declare Xmin = min_extent(THING1).x;
#declare Xmax = max_extent(THING1).x;
#declare Zmin = min_extent(THING1).z;
#declare Zmax = max_extent(THING1).z;
// Trace the rays
#declare Total1=0;
#declare Total2=0;
#declare X=Xmin;
#while (X<Xmax)
  #declare Z=Zmin;
  #while (Z<Zmax)
    // Trace THING1
    #declare P1=trace(THING1, <X,100,Z>, -y);
    #declare P2=trace(THING1, <X,-100,Z>, y, Norm);
      #declare Total1 = Total1 + P1.y - P2.y;
    // Trace THING2
    #declare P1=trace(THING2, <X,100,Z>, -y);
    #declare P2=trace(THING2, <X,-100,Z>, y, Norm);
      #declare Total2 = Total2 + P1.y - P2.y;
  #declare Z=Z+Step;
  #declare X=X+Step;
#declare Volume1 = Total1*Step*Step;
#declare Volume2 = Total2*Step*Step;
#debug concat ("Outer volume = ", str(Volume1,-1,-1),
#debug concat ("Inner volume = ", str(Volume2,-1,-1),
#debug concat ("Volume = ", str(Volume1-Volume2,-1,-1),
