POV-Ray : Newsgroups : povray.newusers : Re: Toruses are making me cry. Server Time
21 Mar 2026 01:00:25 EDT (-0400)
  Re: Toruses are making me cry. (Message 1 to 3 of 3)
Subject: Re: Toruses are making me cry.
Date: 15 Sep 2004 18:20:00
Message: <web.4148bf56e713e40a8c7259570@news.povray.org>
>   (By the way, even if you "translate" a torus or apply other
> transformations to it, the torus will still be sitting in the
> origin, so the transformations you apply to the torus will
> actually not affect the complexity of the ray-torus intersection
> solving.)
Uh-oh.  I was following you, agreeing with you, nodding my head, (and you
are right about the simplifications, at least in hand calculations, I've
done them; I don't know anything about the programming) until I got to this
part.  Could you explain this a bit further, at the risk of hijacking the
thread?
Thanks
Dave Matthews
Date: 15 Sep 2004 19:15:44
Message: <4148cd20@news.povray.org>
> > solving.)
> thread?
  As I explained recently in another thread (and probably another group),
transformations are not applied to objects. Instead, the inverse
transformations are applied to the ray before testing its intersections
against the object. (More explicitly: All transformations are collected
into a single transformation matrix, the inverse of this matrix is
calculated (at parse time), and when testing the ray against the object,
the ray is first transformed with this inverse matrix.)
  This has clear advantages: *Any* raytraceable object can be "transformed"
with the standard transformations. In fact, if you added a new object to
POV-Ray, you wouldn't have to worry about its transformations: The
transformation logic in POV-Ray already takes care of this for you,
regardless of your object. (And in fact, many primitives may be so
complicated that transformations would not be possible to be applied
to them at all.)
  The disadvantage is that since the ray must keep straight even after
transforming it, only linear transformations are possible. (This is
the reason why there are no non-linear transformations in POV-Ray.)
Date: 15 Sep 2004 23:02:10
Message: <cjameshuff-F4DB07.23021015092004@news.povray.org>
In article <4148cd20@news.povray.org>, Warp <war### [at] tagpovrayorg>
A tiny correction: only affine transformations are possible. Scaling,
rotation, and shearing (and combinations of these) are linear
transforms, translation and combinations of translation with the others
are affine transforms. What you can't do are things like transforming a
cylinder into a cone, or adding ripples to a plane. The transformation
must preserve collinearity, points on a straight line must remain on a
straight line after transformation, and it must be invertible (or
reversible).
Basically, if you have a torus at < 1, 2, 3>, the camera rays being
tested against that torus are translated by <-1,-2,-3>, so they hit the
torus at the origin. The points are then transformed back to their
"global" positions.
http://tag.povray.org/
