POV-Ray : Newsgroups : povray.newusers : RGB<->HEX Server Time
20 Nov 2025 20:46:18 EST (-0500)
  RGB<->HEX (Message 1 to 5 of 5)
Subject: RGB<->HEX
Date: 9 Sep 2004 21:35:00
Message: <web.4141045b864bcff549700cac0@news.povray.org>
Is there a simple way to convert a hex value into Pov's RGB system?
I'm not sure what exactly to call Pov's vector system so I had difficulty
researching this myself. If anyone can help me, I would appreciate it. I'm
sure somebody out there is able. :)
Thanks,
~Mike
Subject: Re: RGB<->HEX
Date: 9 Sep 2004 22:17:22
Message: <41410eb2$1@news.povray.org>
First, convert the hex value into three numbers from 0 to 255 by splitting
it up into 3 sets of 2 digits and interpreting each pair of digits as a
single number.
To do this, take the first of the two digits, translate it to a decimal
number (0=0, 1=1, 2=2, 3=3, 4=4, 5=5, 6=6, 7=7, 8=8, 9=9, A=10, B=11, C=12,
D=13, E=14, F=15) and multiply it by 16. Then take the second digit and
translate it the same way, and add that to the first part. This should give
you a number from 0 to 255.
Then take those three numbers and put them in a vector and scale the vector
by 1/255.
So for example, with the color #36F0CF :
36 -> 3*16 + 6  = 54
F0 -> 15*16 + 0 = 240
CF -> 12*16 + 15 = 207
color: rgb <54, 240, 207>/255
It would probably be possible to make a macro that automates this process.
One may already exist.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 9 Sep 2004 23:10:00
Message: <web.41411a7c338914b349700cac0@news.povray.org>
> 36 -> 3*16 + 6  = 54
Wonderful; that's a huge help. Thanks a bunch!
Actually it's partially automated for me - GIMP, my main image manipulation
piece, automatically gives a hex value for RGB and vice versa, so I just
need to do the /255 part.
Thanks again,
~Mike (desperately hoping this reply doesn't register as a new topic)
Date: 10 Sep 2004 13:06:19
Message: <kurtzlepirate-085462.19061810092004@news.povray.org>
In article <web.4141045b864bcff549700cac0@news.povray.org>,
 "Mike Thorn" <films!@!roboticsresources.com> wrote:
> Hi,
> Thanks,
> ~Mike
hi,
try this :
//  --- the macro -------------------------------------------------------------
#macro hex2rgb (hexString)
  #macro hex2dec (theHexValue)
    (asc(theHexValue)>64?asc(theHexValue)-55:asc(theHexValue)-48)
  <16*hex2dec(substr(hexString,1,1))+hex2dec(substr(hexString,2,1)),
  16*hex2dec(substr(hexString,3,1))+hex2dec(substr(hexString,4,1)),
  16*hex2dec(substr(hexString,5,1))+hex2dec(substr(hexString,6,1))>/255
//  --- sample ----------------------------------------------------------------
#declare HexColor = "36F0CF";
#declare PovColor = hex2rgb(HexColor);
#debug concat("\n Red = ",str(PovColor.red,7,6)," Green =
",str(PovColor.green,7,6)," Blue = ",str(PovColor.blue,7,6),"\n")
Date: 10 Sep 2004 14:20:01
Message: <web.4141efa6338914b321ba3a7e0@news.povray.org>
> Hi,
> Thanks,
> ~Mike
Hi mike,
heres a color picker around 300kb and can pick  values from  anywhere on
screen
displays rgb and hex at same time. and stays on top so you can see it easy.
http://www.datastic.com/tools/colorcop/
heaps features include selectable zoom etc.
sprocket aka mongke :)
